Fox fork advice
Tricky1
by Tricky1
Considering a used 2013 Stumpjumper. The bike comes with a 2013 FOX Float CTD Evolution 26 (140mm) fork, and I'm finding limited info. I've read a recall for the 2013 FOX Float CTD 26 140mm fork (non-Evolution series) is in effect, but I'm not sure if there is a difference between the Evolution and without? Honestly, they might be the same fork for all I know? Apparently the 2013 forks were blowing through and are being fit with 2014 dampers I believe.
Hoping someone has owned this fork or can offer some insight while I await Fox's reply. Thanks.
