Which BB for 2010 Scott Spark 10?
Mine is integrated as the pf picture the problem is Scott apparantly made two versions one pf30 and one BB92 both integrated.....the bsa you picture is before this so there are three standards... and I have either pf30 or bb92...
The unbearable wallet lightness of being a weightweenie
Call Scott with Serial Number.
For certain parts stiffer is more important than lighter.
- bikerjulio
Shimano have never made a BB30 crankset. So by deduction it's either a BB90 or BB91.
And given this article in 2010 said BB90, I'm guessing it's BB90
or maybe not Is that only on road bikes? In which case it's BB91
BB86/BB90
Some frame manufacturers like Scott, Trek, and Giant have tried to take the BB30 system even further, creating the “integrated bottom bracket.” This system requires yet another new bottom bracket shell sizing, designed around the diameter of bearings in existing external cup bottom brackets. The technology behind BB86/90 systems is similar to BB30, but it is designed to be used with existing external cup, two piece cranksets. Just like BB30, bearings are pressed into the shell, eliminating the need for cups and threads, and again, eliminating more weight. BB86 and BB90 get their names from the width of the shell (86mm and 90mm wide), while BB30 got its name from the 30mm spindle diameter. Shimano’s own adaptation and proprietary interpretation of this technology is called the “Shimano Press Fit” bearing system. Shimano has not yet adapted any of their products to the BB30 system, and is instead investing its resources into its incompatible Press Fit systems.
There's sometimes a buggy.
One.
One.
Yes, but there are adapters for bb30 and Shimano.
Sent from my Nexus 9 using Tapatalk
- bikerjulio
True, although I don't know if BB30 to Shimano adapters were ever used in an OEM situation.
Seriously OP, you could have had the crank off in 2 minutes and had a look.
My money is on BB91
My money is on BB91
One.
One.
Scott Customer service just says BB92 and does not seem to know if it´s 41A or B
A dealer in Germany specifies:
"In this case Scott used a road bottom bracket size,
Shimano Dura-Ace SM-BB92-41B Press Fit Bottom Bracket Cups."
I specifically asked again if I should not use 41A (the mtb standard) but they were adamant that I should use the road version.
I write this mainly for others seeking the same info in the future.
- bikerjulio
That's what I said.
BB91 and BB92 are the same thing BTW. One type.
see here http://www.competitivecyclist.com/shimano-bb92-bottom-bracket
One.
One.
mrowkoob wrote:Mine is integrated as the pf picture the problem is Scott apparantly made two versions one pf30 and one BB92 both integrated
Really? I didn't think Scott had ever made a PF30 bike?
Edit: Also arent BB92 41A and 41B identical in dimensions but with heavier internal sealing on the 41A?
Scott seem to have done a few PF30 MTB frames but I've got no idea how many were sold to plebs.
I'm guessing they were made so pro's could run the BB30 XX or XX1 cranks which save a decent bit of weight over the GXP versions. Schurter has been running the BB30 cranks pretty much since SRAM XX was released.
