Budget lightweight FS
TheRookie
by TheRookie
Here is my home built Litespeed Niota Al, not sure of the exact year, front triangle appears to be circa 2006, but it has the later rear on it, most parts came from my old hardtail but my legs needed some respite on the rougher sections! (photo taken before saddle and rear mech were finalised).
Full spec - sorry about the formating but its a copy and paste from Excel!
Frame
Litespeed Niota AL frame with shock bolts 2128
Fifth Element shock with bearings and spacers 244
Frame blanking bolts 0.5
Drivetrain
Deore XT (BB70) HT2 BB 87
BB spacers 4.1
Outer chainwheel retaining bolts 20
Carbon fibre bash 27
Deore XT HT2 RH arm 368
Deore XT HT2 LH arm 220
HT2 preload adjuster 3.5
On-One Ringmaster 61
XT SPD 349
Rear cable inner 11
Rear cable front outer 8
Rear cable mid outer 8
Rear cable rear outer 6
Deore XTR shadow rear mech 197
Chain 244
Brakes
Shimano ST-M765 XT front 390
front calliper bolts 12
Shimano M765 lever/M965 XTR rear 276
rear caliper bolts 14
Seat
Chinese full carbon seatpost 183
USE plastic 27.2/31.6 shim 24
Cheap bolted seat clamp 20
Charge knife Ti 222
Steering
Headset 72
Headset weather cap 10
Manitou Skareb Elite forks 1445
Mt Zoom alloy/titanium top cap 5
Superstar 80mm stem with bikehut faceplate 122
Syncros UD Carbon bars 137
KCNC foam grips 15
Black bar end caps 6
Carbon Headset spacers 8
Wheels and tyre
A2Z hub, Sapim race spokes, alloy nipples and ZTR Alpine rim 629
Rime tape and valves 13
Sealant 60
Rocket Ron EVO 2.25 Folding 479
160mm A2Z Teppen Yaki spade floating 89
Bolts 10
Shimano XT QR skewer 58
Novatech 772hub, Sapim race spokes, alloy nipples and ZTR Alpine rim 797
Sealant 60
Shimano M760 Cassette 296
Alligator rear disc 72
Bolts 12
Shimano XT QR skewer 68
Total 10,081g
It may put on some weight as I'm looking for a slightly better fork, the lack of compression damping and flex on this are now an issue as I'm riding it harder than the old HT, long term aim though is to sneak it below 10Kg.
The frame rides really nicely, I'm still playing with the rear sag but it's really smooth and linear feeling, the shock gives a great pedal platform and as its slightly shorter than the original Fox it has lowered the BB and relaxed the Geo slightly, numbers are now similar to a Giant Anthem.
This has cost me £800 (€960, US$1280) as its stands which I think is pretty good value, from here the weight saving is going to get expensive though!
TheRookie
by TheRookie
Oops, nope, 10.081Kg - original post corrected.
