It is currently Thu Jan 18, 2018 7:06 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject:
PostPosted: Mon Feb 23, 2004 5:03 pm
Frankie - B wrote:
Nik please stay away from those forks, their prone to breaking!
Where and how?
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
 Post subject:
PostPosted: Mon Feb 23, 2004 6:32 pm
Administrator
nik, do i have to tell you how aluminum cracks? because the fork is so light it cracks. most of the time at the crown.
{USERNAME} wrote:
 Post subject:
PostPosted: Mon Feb 23, 2004 7:21 pm
Frankie - B wrote:
nik, do i have to tell you how aluminum cracks? .
No.
Hmmm interesting.
 Post subject:
PostPosted: Mon Feb 23, 2004 7:50 pm
Administrator
nikh wrote:
No.
I already thought so! :D
 Post subject: Pace fork
PostPosted: Wed Feb 25, 2004 1:26 am
I ride / race singlespeed with a 420mm Pace RC31. I really like the ride quality of the Pace - the carbon does take the edge off the hits much nicer than the stock Cromo rigid fork. It is also very stiff laterally - it steers very precise. But, like any rigid fork, it's not meant for jumps / big drops.
My RC31 does not have safety (lawyer) tabs, so you should check your quick release often if you run disk brakes.
I'm a little weary of Titanium forks, especially the XACD one - titanium is really prone to failure if not welded perfectly. I should know - I broke one at the crown. The Hilset fork mentioned earlier looks very much like the XACD. Spicer forks are made by XACD. If you want a Ti fork, I'd suggest the more pricey Morati fork - it's built with thicker, stronger tubing, and the welds look more consistent.
I do have a 400mm Kinesis Maxlight coming shortly (for a different bike), and will be likely trying additional forks with it. The IF no travel fork, Kelly and Sycip segmented forks are ones I'm considering.
In general, most all rigid forks will be harsh, and the best way to make up for that is to stay off the seat on bumps, letting your arms and legs absorb the hits, and keep less weight over the handlebars. You can also run bigger tires at lower pressures for more comfort (eek - no weight savings!). You'll still save significant weight by switching from a full suspension fork to rigid (500+ grams).
 Post subject:
PostPosted: Wed Feb 25, 2004 3:19 am
I run a Pace rigid on my single speed (a gaint MCM frame) Love it! Mind you I am running 2.35 tires and a full carbon frame/fork. It is just as good as any SID I ever ran.
Pace forks are great. I wish they were available in the states. I have also heard great things about the new magura fork. One of my friends in Wales is riding one and thinks it better than his Pace Air.
 Post subject:
PostPosted: Fri Feb 27, 2004 12:14 am
I am seriously considering the Spicer Ti or the Kinesis Maxlight but I'm not sure which to choose ...I want to try racing with one of them so I think the aluminum of the Kinesis may be too harsh although it does have the swept design ...one potential problem is that they are only 398mm
Does anybody have experience with the Spicer Ti? ...I could get the 80mm suspension corrected version that is 430mm ...I think that would prevent me from messing up my geometry with the 398mm Kinesis
 Post subject:
PostPosted: Fri Feb 27, 2004 2:59 pm
i was looking for a spicer ti fork too but after searching a lot om mtbr singlespeed forum i found lots of broken forks, most at the welds.. brake a fork is not a very pleasant surprise going down the hill at high speeds.... but its cheap and light and sexy too.
hey
ho
lets go!
There are no new unread posts for this topic. Length of the chain?
TonyM
9
1160
Sat May 20, 2017 9:24 pm
boots2000 View the latest post
There are no new unread posts for this topic. srm crank length
simoncx
7
503
Tue Oct 10, 2017 4:23 pm
simoncx View the latest post
There are no new unread posts for this topic. Crank length confusion
Greatestalltime
19
1852
Tue Jul 18, 2017 1:46 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Reach and top tube length
cmcdonnell
9
1416
Sat Mar 11, 2017 4:44 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Which frame size and stem length?
TonyM
Tue Sep 12, 2017 5:22 pm
TonyM View the latest post
Users browsing this forum: andrew9 and 7 guests
