brake pad
Yes, why wouldn't it be?
Ice tech only makes a difference if you would otherwise overheat the pad, as you can't brake as hard at the rear (it locks up) then you are less likely to overheat it.
You need to be doing some serious downhill to overheat the pad anyway.
'finned'?
Yeah I know, i thought he may have used some easy to lose (non find) pads.....
