TheRookie
by TheRookie on Thu Dec 11, 2014 6:38 am
Rich_W wrote:The 6mm hex is on the threaded end which is counter-intuitive. Not sure why they did that.
Makes sense to me, apply the torque to the end where the torque is reacted against (through the threads) and not all the way along the length of the 'bolt'. As the threaded end needs to have a smaller internal diameter anyway (to maintain material thickness at the root of the threads) so reducing that end for the 6mm Allen key will save weight over putting it the other end, also it means the main tube can have a larger ID (more easily) as you arn't trying to machine the bore between the 6mm hex one end and the smaller ID at the threaded end the other.
Rich_W
by Rich_W on Thu Dec 11, 2014 8:29 pm
I'm with you Rookie... Makes total sense from a design standpoint... I just mean your brain is trained to look for the skewer on the other end...
PSM
devinci
by devinci on Fri Dec 12, 2014 12:43 am
I have both the carbon-ti 15mm and 12mm axle here. Not used them yet. For you guys interested in light axle, their respective weight is 35g and 34g
Grannen
by Grannen on Sat Dec 13, 2014 10:30 am
Are you sure?
The rs1 ps hub uses a 27mm steerertube, and 15mm maxle ultimate to hold hub and tube in place. If I understood info that is
Maxle ultimate is also used on rs pike fork i think
HaakonJohansen
by HaakonJohansen on Thu Dec 25, 2014 3:55 pm
Just bought one to use for street/DJ use. Haven't really used it a lot yet (because of it being winter), so can't say anything about strength, but it sure looks clean, makes the bike lighter, and makes it a bit harder to steal the front wheel. Mine (RS version) weighted in at 26g i think.
Cheers!
by Cheers! on Tue Feb 03, 2015 2:28 am
DanW wrote:Anyway, if you get a puncture in an XC race and you are towards the front then it is pretty much race over regardless of a second or two extra to get a wheel out... non?
Yup! Might as well take the rest of the ride easy or think about heading back to the car.
PSM
by PSM on Tue Feb 03, 2015 8:39 am
doccoraje wrote:My 142 Maxle is working great, less than half the weight of the DT it's replacing.
What bike?
njee20
by njee20 on Tue Feb 10, 2015 4:27 pm
Cheers! wrote:DanW wrote:Anyway, if you get a puncture in an XC race and you are towards the front then it is pretty much race over regardless of a second or two extra to get a wheel out... non?
To be fair, there have been plenty of examples of people changing punctures and still getting a decent result, plus points matter. Why even carry tools/pump etc otherwise? I don't really see allen key axles as a real issue here though, any through axle is more of a faff to remove than a traditional QR wheel.
jooo
by jooo on Wed Feb 11, 2015 3:33 pm
I've seen a few slick changes where the mechanic has the hex key ready in hand and it doesn't really take any longer than unscrewing a QR thru-axle.
Some of the stops have probably been quicker than neutral service changes in road racing.
doccoraje
Carlin
by Carlin on Mon Feb 23, 2015 11:05 pm
Just a quick questions has anyone on here replaced the QR on the RockShox forks? They are horrible I've ruined that mushroom black cap so many times etc.
So looking at replacement, I don't mind bolt or quick release just something better than the standard its crap.
The forks are RS Sids 14 100mm carbon steerer model
