I need a regular Shimano-compatible 9/10 speed freehub body for the prior generation (non-DT 240) SRAM Rise 60 wheel. It’s part number: 11.1918.000.000 and SRAM has them backordered for the foreseeable future.
I’ve got a pair of Rise 60’s with an XD driver set up 142x12 lying around and am wanting to employ them for use with a Single Speed build - so I need to convert the rear wheel to a conventional free hub and get whatever end caps would be necessary to install it for use with a 142mm thru axle (likely the driveside end cap).
If there's anyone out there that may have converted a Rise 60 wheelset from 9/10 speed to 11 and would like to part with their old freehub body, I'd love to take it off of your hands.
In Search Of: SRAM Rise 60 9/10 Speed Freehub Body
FYI current gen Rise 60 are not DT 240, only Roam and Rail.
Regardless I've got the old gen Rise 60. I use the XD freehub. I have a 9/10speed freehub. I've only ever used the 9/10speed freehub with QR axle so not sure if I have the 142x12 endcap for it. I'll have a look. If I do I'm happy to part with them. The catch being I'm in Australia. Get in touch if you don't source one locally.
@Grover: Hm. I thought new new Rise 60 had switched to DT as well. Oh well...
I'm located in the 'States, but even having it shipped from Australia could be a speedier option for me. I'll shoot you an email if I can't find a local alternative by week's end. Thanks!
