easton ec90 seatpost
Hi guys
Looking for a post for a FS 29er build. What would you guys recommend between the ec90 post or a ebay climax post? Is the easton stronger? Can it be tuned? Is the climax weaker then a kcnc?
Price is no issue. Weight, tunability and strength are my concern
Don't bother with the Easton if weight is a concern, it's a boat anchor. The cradle is heavy as hell and the design isn't particularly fantastic. There is a thin curved plate that sits under the barrel that each bolt is threaded into. Fiddly as hell & bugs the hell out of me every time I go to clean it.
Have a look at the Hylix (link below) or. KCNC Pro scandium.
http://tinyurl.com/mq93l27
Any particular reason for your choice of EC90? I'd mostly echo the above comments regarding an EC90 seatpost.
Are you open to other brands?
Personally, I really like the bontrager XXX post for a balance of strength and light weight. Though I have had good luck with the KCNC lasting the last 3 years on my road bike, I'm not sure I'd trust it on my MTB.
- the_marsbar
- Contact:
I've used an Mcfk seatpost this season, and so far I really like it. It's light (around 110 g for 27.2 x 400 mm), and supposedly quite strong (max rider weight 100 kg), and it's more comfortable than the Save seatpost that I had on my Cannondale. Also, they do both matt and shiny versions
I am probably going to stick to the KCNC. Price was not an issue because I already had a KCNC and because I could have a good price on the easton. No way im going to pay for a Mcfk
In any case, the bike should end up decently light
