It is currently Sat Jun 24, 2017 8:32 am
Post new topic  Reply to topic  [ 417 posts ]  Go to page 1 2 3 4 528 Next
 Post subject: Cannondale FSi builds
PostPosted: Tue Sep 30, 2014 3:49 am
Does anyone have a FSi build to show off?
~GFeldy~
S Works Tarmac w/ EPS
S Works Epic Blurple tuned
Kitsbow
FS-i - Sold
Scalpel custom - Sold
EVO - Sold
PostPosted: Tue Sep 30, 2014 8:22 pm
Nothing?
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
PostPosted: Tue Sep 30, 2014 8:47 pm
Delivery time for those is about march 2015...
Fuelled by kofein
PostPosted: Tue Sep 30, 2014 8:55 pm
Some people here are racing them already. They must be available in other countries as well :)
I'd like to try one, but I'm curious about the increase in reach, and what it means wrt. sizing. I have a feeling I'd fit the medium better than the large (179 cm, currently riding a large F29).
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Tue Sep 30, 2014 9:43 pm
I was told mine will be arriving in Oct.
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
PostPosted: Tue Sep 30, 2014 9:46 pm
[quote="I'd like to try one, but I'm curious about the increase in reach, and what it means wrt. sizing. I have a feeling I'd fit the medium better than the large (179 cm, currently riding a large F29).[/quote]
I race a Med Scalpel and debated on getting a small FSi. I think the real advantage to the FSi is the lower stack.
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
PostPosted: Thu Oct 02, 2014 4:01 am
I think they are already available in Europe.
PostPosted: Thu Oct 02, 2014 10:08 am
I am not familiar with the exact geometry of the FSi and the Flash. But if the stack is lower (which I believe it is from marketing) then it makes sense that the reach is longer. The reach increases as the stack decreases due to the head angle sloping forwards and down. A rough calculation would be 3mm more reach for every 10mm less stack.
EDIT found the geo.
Once you account for decreased stack a large FSi is 2mm longer than a large Flash, and a medium FSi is the same reach as a medium Flash.
A lot of people used to run severely negative stems on their Flash's. So to get the same position you either use spacers to make the stack similar and use the same stem. Or use a more standard stem angle that will result in less drop to get your bars in the same as your old position.
This is a good tool.
http://yojimg.net/bike/web_tools/stem.php
You won't be able to do an exact calculation as head tube angles are different (69.5 for FSi and 71 for Flash). I'd suggest using 70 to meet in the middle.
Example, if I rode a large Flash with no spacers and a 100mm -25degree stem. I'd ride a large FSi with no spacers a 90mm -10degree stem. My bar position would be identical to the millimetre both vertically and horizontally.
Grover's Grumblings
Grover's Garage
PostPosted: Thu Oct 02, 2014 10:51 am
Thanks a lot for that. I have used some of the stack/reach calculators around, but I hadn't seen that one.
The F-Si should be able to take an 80 mm stem, so probably I would be better off with a large... I'll see if I can try one.
PostPosted: Thu Oct 02, 2014 4:31 pm
EDIT found the geo.
Does the Cannondale measurement on the Flash take into account the headset that sits on top of the actual headtube and the fork crown? I have a feeling the new fork and bearing design on the FSi will lower the front end a lot more than we think.
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
PostPosted: Mon Oct 06, 2014 4:07 pm
I'm sure we can pick this build apart.
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
PostPosted: Mon Oct 06, 2014 4:54 pm
Is it yours?
PostPosted: Mon Oct 06, 2014 7:47 pm
the_marsbar wrote:
Is it yours?
No. But I am going to get the Carbon 1 and convert it to a XTR 11speed.
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
PostPosted: Tue Oct 07, 2014 6:45 am
I saw it on Facebook right after I asked. I asked the guy who owns it, and he's 181, with a BB to saddle height of 76 cm (and riding a medium frame), in case anyone is interested.
PostPosted: Tue Oct 07, 2014 3:40 pm
I run a 74cm saddle height and I'm going to get a Med as well. I'm worried if I go to a small I may not be able to get a normal size bottle in the triangle.
~GFeldy~
Kitsbow
FS-i - Sold
EVO - Sold
There are no new unread posts for this topic. Cannondale Scalpel-Si builds
ChrizZZz
14
2832
Wed May 17, 2017 10:35 am
ChrizZZz View the latest post
There are no new unread posts for this topic. Lightweight Mr Pink Builds?
peezy
Fri Oct 21, 2016 8:40 pm
KarlC View the latest post
There are no new unread posts for this topic. S5 frame weight & lightish S5 builds
Shrike
33
2451
Tue Jan 03, 2017 6:14 pm
ryanw View the latest post
There are no new unread posts for this topic. Attachment(s) Show us your CAAD12 frameset (non disc) builds
[ Go to page: 1 2 3 4 ]
caad10dotcom
45
9827
Tue Mar 21, 2017 12:15 am
wolfesquire View the latest post
There are no new unread posts for this topic. Huge bike / frame / wheel sale : Cannondale F-SI, Specialized Crux, BMC TMR02, Cannondale Evo Hi-mod, Roval CLX64, Power
prebsy
Tue Apr 18, 2017 1:32 pm
prebsy View the latest post
Users browsing this forum: No registered users and 13 guests
