Post new topic Reply to topic  [ 7 posts ]
PostPosted: Wed Feb 05, 2003 7:26 am
I wanted to buy FRM CU2-Al ISIS bottom bracket, it is very light only 135g and it is with ISIS standart, perfekt match for my requirements, but the spindle is made from 7075 Alloy, what made me doubtful. As far as I know nobody jet hasn't used an alloy to make bottom bracket spindle.
What are your opinions? Is it safe, is it recomended to risk?
Does anyone knows anything about those bottom brackets?
P.S My weight is 75kg.
Light weight everything!
 Post subject:
PostPosted: Thu Feb 06, 2003 8:39 pm
A manufacturer making BB spindles from Aluminium is nonserious in my eyes. :shock:
 Post subject:
PostPosted: Fri Feb 07, 2003 4:12 am
American Classic ISIS BB weighs 140 grams and it has a steel axle.
They are not in stock but they should be here by 1 March.
www.amclassic.com
biketuna
 Post subject:
PostPosted: Tue Feb 11, 2003 9:09 am
Cannondale made a BB axel in aluminium, on their Coda Magic 900 crankset. And yes, I have seen one that had bend.
 Post subject:
PostPosted: Tue Feb 11, 2003 9:22 am
Thanks guys!
I found that there is no real proof that Alu bottom bracket is very bad, ok I admit that it is much less stronger than for example American clasics bb, but as I didn't get enough information, I will just have to buy it and test by my self.
Thank you all!
 Post subject:
PostPosted: Wed Feb 12, 2003 2:15 am
Let us know how it works !!
 Post subject: Al BB
PostPosted: Tue Mar 04, 2003 11:57 pm
Al BB is a new development, but the larger diameter of the ISIS axle makes the use of al possible. The problem is we've had skinny taper axles for so long, where al wouldn't be strong enough. Also the ISIS interface spreads the load better than taper.
That said, Crank bros, am classic do light Ti and cromo ISIS BBs which will last longer if you decide to undo the crank bolts or throw things at it etc...
Users browsing this forum: No registered users and 13 guests
There are no new unread posts for this topic. looking for bottom bracket
in MTB
cycleforlife
Sat Jun 09, 2012 3:31 am
cycleforlife View the latest post
There are no new unread posts for this topic. THM Bottom Bracket
in Wanted
krzysiekmz
Sat Mar 16, 2013 6:29 pm
krzysiekmz View the latest post
There are no new unread posts for this topic. Enduro XD-15 Bottom Bracket?
BdaGhisallo
Mon Apr 15, 2013 7:14 pm
rmerka View the latest post
There are no new unread posts for this topic. Attachment(s) Help, SRM FSA K-force - which bottom bracket?
srasmussen
Wed Aug 29, 2012 8:20 am
There are no new unread posts for this topic. Bottom bracket question
BreakfastClub
11
590
Mon Feb 18, 2013 11:13 am
It is currently Sun May 19, 2013 8:07 pm
