My KCNC skewer at the front
Dear weight weenies.
I've got myself a pair of KCNC Ti skewer in MTB length.
For the front, it seems that mine is aliittle bit too short at the thread when installed. Looking at this link here, do u think its a problematic issue? Does all KCNC to user have their thread length the same as mine ?
Thanks .
Thanks .
Could you upload a slightly larger image? I can hardly see the threads.
That skewer will be for a road bike, they just sent you the wrong one.
- Contact:
What fork is that? Could be the forks dropout is thicker than normal.
Could someone verify their length of the threaded end of their FRONT kcnc skewer. Mine is just about 21mm or 2.1cm long as u can see from the picture. At closed position, it's a 100mm front skewer which is correct. I'm suspecting my thread length is a little bit short than usual, but I've got to be sure on this.
Thanks.
Thanks.
I realise this is going to be too late for wheeler, but in case anyone else comes across this thread whilst Googling the same problem as I did, I'm going to put up my lengths of my KCNC titanium skewers which are a too short for a BH Ultralight 2014 model (both front and rear).
KCNC titanium skewer lengths with lever closed:
-Front - 120mm total length and 20mm of thread.
-Rear - 155mm total length and 20mm of thread.
-Nut has a thickness of 9mm ergo allowing for full thread engagement, the front has a maximum length of 111mm and the rear 146mm.
