29er high front end question
cyclemanpat
by cyclemanpat
Just got a Flash 29er and love the bike, but hate the high front end...I am only 5'9. I have the -15degree opi stem and still need the front end lower. I had a thought....could you run a riser bar up-side-down to get a lower position? Just a thought.....
to go faster....just pedal harder!
bombertodd
by bombertodd
Most bars have upsweep. If you flip them you would have upsweep that goes down (downsweep???). Not sure if it would be comfortable. Do you current bars have any rise to them?
krzysiekmz
by krzysiekmz
There are Ritchey bars with negative drop designed for 29-ers.
You can also get a stem like the one form Leonardi racing.
You can start by removing any spacers if there are any. Lower headset cover can help too.
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
the_marsbar
by the_marsbar
There's no headset cover as far as I know.
cyclemanpat
by cyclemanpat
I also just found the Syntace vector Low10.....has a -10 degree, seems like an option :D
FredBloggs
by FredBloggs
Same problem here, yet I'm 5' 5"
I have a specialized stem with a shim (supplied) in it, I think it's a neg 19, possibly more.
Might help solve your issues.
tonytourist
by tonytourist
The Leonardi stem is awesome. I bought one for my friend from R2, if I rode a Canondale I would have one for sure.
Juanmoretime
Administrator
by Juanmoretime
This looks like it might do the job.
viewtopic.php?f=10&t=127063
RESIDENT GRUMPY OLD MAN.
weeracerweenie
by weeracerweenie
I'll chuck my vote in for a leonardi stem. I have one of the -20 in 120mm... It's still to short but 140mm isn't an option "sigh". Also consider a fork reducer. Common on lefty forks, reduces the travel of the fork and brings the front end down.
I guess there's worse hobbies than making a bike light? Right?
weeracerweenie
by weeracerweenie
Thanks for the thread think @juanmoretime, I clicked it and was like "hey that looks familiar" haha
cyclemanpat
by cyclemanpat
I heard a few pro's have their lefty fork down to 70mm....is that a option for us "non-pro's"?? if yes how would I get the proper spacer?
SpeedyChix
by SpeedyChix
I ended up running a Ritchey Pro 30 deg stem setup negative.
adrenaline junkie
cyclemanpat
by cyclemanpat
Flash uses OPI stem system, so a ritchey stem wouldn't work
