It is currently Thu Jan 19, 2017 1:51 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Aug 06, 2014 7:52 pm
i mainly ride road bikes, so when it comes to mtn bikes, i'm like 10 years behind in what's current. i plan to use the mtn bike for some off road, but mainly as
a XC ride.
i'd like to upgrade components to newer ones on my current Litespeed Ti frame...and would like to do the following...
1. go single crank front
2. need new brakes, can go disc and thinking about Enve XC wheels
3. have Lefty carbon fork, so that will go on with Project 321 adapter
4. need new shifters, probably 10 speed all i need as far as range...maybe 34T front and 11-38 rear?
5. have Enve seat post, straight handlebar already.
6. have Chris King headset that will fit Lefty/P321 adapter
7. want to go tubeless, get Stan's tubeless kit?
thx for any recommendations.
- AX Lightness Vial EVO D + DA9070 + Enve SES 2.2 tubeless with carbon hubs
- Parlee Altum + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Thu Aug 07, 2014 12:10 pm
That sounds like a wild ride.
Since a lot of us here are visual, post some pics of the current bike set up so the recommendations can flow better.
Assumption is that this is a 26" build, but wonder if 650b would fit in the frame without altering the geo to badly.
PostPosted: Thu Aug 07, 2014 12:29 pm
First thing make sure the new fork isn't terribly longer than what the frame was built for. Too long a fork can really ruin the handling, all the more for XC application.
PostPosted: Thu Aug 07, 2014 1:26 pm
thx. i'm assuming that all Lefty forks can be adjusted via spacers, so anything can actually fit. so if i stayed with a 26" rear, theoretically, i can fit a 29r up front...odd as it seems.
it was a 26 and not certain a 650B can fit. also, i bought the adapter from Litespeed that allows you to put a rear disc brake in back.
the drive train is old...at least 14 yrs old...so its a 9 speed cassette. not sure if i will go Di2 since its not what i ride all the time...maybe nows the time to buy this years or last XTR on the cheap. if that's the case, rear shifter, hydraulic disc brakes, 1x10 set up. will take pictures.
PostPosted: Thu Aug 07, 2014 2:02 pm
Putting a 29er wheel in front will add (622-559)/2 = 15.75mm of extra height, assuming you keep the same fork travel. That's probably as much as you can safely add, beyond 2-3cm bets are off. That's not to say some people don't go further, and aren't boasting how "slack" their headtube angles are, but again, for XC riding you want quick handling. Be aware that going 650b would also rise the BB, which again influences handling. Nowadays' bigger tyres add another cm or so. Again, not saying it hasn't been done, or I haven't been playing with it. Just things to consider before pouring money into an older frame project.
Don't read that as discouragement, though. Some Lefty mods on non-Cannondale frames look absolutely spectacular. Just make sure get the an enjoyable ride out of it.
PostPosted: Thu Aug 07, 2014 3:46 pm
appreciate the info. i lived in the 26" world...and 650B and 29" is a whole new universe.
There are no new unread posts for this topic. Attachment(s) older alum lemond
simoncx
Mon Dec 19, 2016 3:54 am
mike View the latest post
There are no new unread posts for this topic. UCI legality of older TT frames
davidalone
Tue Sep 27, 2016 9:40 pm
CarlosFerreiro View the latest post
There are no new unread posts for this topic. Can some1 help? UCI regs for older tt bikes...
davidalone
Fri Sep 23, 2016 1:29 pm
Calnago View the latest post
There are no new unread posts for this topic. Shimano E-Tube Project - Older Versions
gustavocarvalheira
Fri Dec 02, 2016 11:01 pm
androidavies View the latest post
There are no new unread posts for this topic. New style (2015+) campy rubber hoods on older (09'-14') lever bodies
helldiver
Thu Jul 07, 2016 9:13 pm
helldiver View the latest post
Users browsing this forum: No registered users and 3 guests
