It is currently Fri Aug 18, 2017 10:14 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Aug 06, 2014 9:22 am
This may be the werid question but ... is it possible to install s900 road gxp crankset in mtb with xx1 style (http://absoluteblack.cc/xx1-style-sram.html) spider on it ?
the crank seems to be the same as xx1 crank ... or maybe the spindle length is different
i am asking because i have one spare s900 lying around :)
something like this ...
PostPosted: Wed Aug 06, 2014 9:41 am
I'm sure the spindle length is different. But I think you should be able to install an XX1-spider.
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Thu Aug 07, 2014 3:24 pm
Spindle will be 5mm shorter. If you have a 68mm BB you should be able to get it to work though.
PostPosted: Sat Aug 09, 2014 4:45 am
spider will fit.
spindle will be shorter. if you have a 68mm bottom bracket shell on the frame you'll be able to install it
q-factor will be narrower. the crankarms will probably hit the chainstays so it won't actually be functional.
Grover's Grumblings
Grover's Garage
PostPosted: Sat Aug 09, 2014 4:27 pm
Read the SRAM framefit doc on their tech page, you should be able to take a few simple measurements to work out if it will fit.
If you've got a 73mm BB you're likely to be out of luck though.
PostPosted: Mon Aug 25, 2014 10:52 am
Ok, will try with spider only and see what happens :)
There are no new unread posts for this topic. SRam Eagle Crankset 3 bolt spider fitting?
in MTB
roeman
7
933
Fri Oct 21, 2016 3:57 pm
commendatore View the latest post
There are no new unread posts for this topic. Weight of SRAM CX1/S900 GXP arms?
hmai18
Wed Dec 28, 2016 3:58 am
hmai18 View the latest post
There are no new unread posts for this topic. brand new SRAM S900 bb/pf30 172.5mm carbon crank-arms
dmoneysworks
Sun Jun 04, 2017 9:21 am
dmoneysworks View the latest post
There are no new unread posts for this topic. Carbon spider for Lightning crankset?
dereksmalls
Fri Mar 03, 2017 8:52 pm
BmanX View the latest post
There are no new unread posts for this topic. Sram Red BB30 chainset (integral spider) fitted to BBRight....
pavlo
Wed May 17, 2017 12:47 am
pavlo View the latest post
Users browsing this forum: Yahoo [Bot] and 6 guests
