It is currently Wed Jan 24, 2018 3:12 am
PostPosted: Sun Jul 27, 2014 2:09 am
So, I just bought a DT Swiss XMM 29 120mm fork off eBay. Came in the box, and still had all of the original documentation in it.
But here's the thing - from the seals to the crown, the stanchions measure slightly more than 140mm.
I'm not complaining, per se; the frame I'm going to use is a 120mm carbon FS.
However, has anyone seen this before? There is no XMM 29 130 or 140 fork listed on DT Swiss' website.
PostPosted: Sun Jul 27, 2014 2:29 am
My older XRC 100 measures 110mm and newer 117mm from the seals to the crown.
Might be the sag that's taken into account?
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Sun Jul 27, 2014 2:42 am
Perhaps. But, the XMM 150 on my 26er AM bike measures 151mm.
And, it gets full travel.
I'll see what happens when I get the bike together and ride it.
PostPosted: Sun Jul 27, 2014 2:52 am
Yes I guess get the air pressure right for you first and brake the fork in after a few rides.
Chris.
Orbea Oiz - xxxx
PostPosted: Sun Jul 27, 2014 2:03 pm
Let all the air out and see how far you can compress it. If it does indeed travel 140 then you somehow have a 140 travel fork (maybe an employee sold you a prototype). My guess is that it won't go full stroke and that DT is using parts that can later be used to make a 140 fork to simplify manufacturing and inventory. They can do this by using long tubes on the top and making the lowers such that there is not enough room to take the whole tube. Later they can make a longer lower part and get a 140 fork. The disadvantage of dong it this way is that the fork will be 20mm taller than it has to be.
For certain parts stiffer is more important than lighter.
PostPosted: Sun Jul 27, 2014 11:00 pm
It compresses down to 10mm with all air removed from the valve.
PostPosted: Sun Jul 27, 2014 11:06 pm
So 130 of travel?
PostPosted: Sun Jul 27, 2014 11:11 pm
So it seems. Interesting stuff.
There are no new unread posts for this topic. WTD: Pro PLT 130mm stem & Pro Vibe 140mm 1&1/4 stem (UK)
in Wanted
DJT21
Sat Dec 30, 2017 9:01 pm
DJT21 View the latest post
There are no new unread posts for this topic. DT Swiss RR411
in Everything wheels
Thenuge
12
1465
Wed Oct 18, 2017 12:34 am
bm0p700f View the latest post
There are no new unread posts for this topic. DT Swiss now with 2:1 16/21 spokes...
Beaver
Fri Jul 28, 2017 1:21 pm
Marin View the latest post
There are no new unread posts for this topic. DT Swiss QR endcaps
ParisCarbon
Sat Oct 14, 2017 1:31 am
stormur View the latest post
There are no new unread posts for this topic. dt swiss dicut 1400
sd5500
Wed May 17, 2017 10:08 pm
Apv View the latest post
Users browsing this forum: No registered users and 2 guests
