It is currently Mon Jan 22, 2018 9:32 pm
Post new topic  Reply to topic  [ 1 post ]
PostPosted: Fri Jun 13, 2014 9:20 am
Hey guys,
I regularly check this forum but this is my first post.
I'm looking to lighten up my 2014 Stumpy. I don't want to spend huge amounts of cash hence why i went the comp version and not the carbon.
It's an AM bike, but i generally ride XC trails with small-mid jumps here and there. When riding and jumping it feels a little heavy and sluggish.
Below are the specs from the Specialized website:
FRAME: M5 hydroformed tubing, EVO geometry, tapered headtube, PF30 BB, ISCG ’05, Command Post BlackLite routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
REAR SHOCK: Custom FOX Float CTD Evolution w/ AUTOSAG, Climb, Trail, Descend settings and reb adj., 195x51mm
FORK: Custom RockShox Revelation RC3, 3P damper, tapered alloy steerer, 3-position compression and reb adj., 15mm thru-axle, 150mm travel
HEADSET: 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM: Specialized Trail, 6061 alloy, 4-bolt, 6-degree rise, 31.8mm clamp
HANDLEBARS: Specialized All-Mountain, low-rise, 7050 alloy, 750mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS: Specialized Sip Grip, light lock-on, half-waffle aramid-infused, S/M: regular, L: XL thickness
Upgraded - Race Face
FRONT BRAKE: Formula C1, alloy caliper, metallic pad, S/M: 180mm, L: 200mm rotor
Upgraded - Shimano XT
REAR BRAKE: Formula C1, alloy caliper, metallic pad, S/M: 160mm, L: 180mm rotor
BRAKE LEVERS: Formula C1, hydraulic disc, tooled reach adj.
FRONT DERAILLEUR: SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
REAR DERAILLEUR: SRAM X9 Type 2, 10-speed, mid cage
SHIFT LEVERS: SRAM X7, 10-speed, aluminum trigger, zero loss
CASSETTE: SRAM PG-1030, 10-speed, 11-36
CHAIN: SRAM PC 1031, 10-speed, PowerLink
CRANKSET: Custom SRAM S-1250, 7050 alloy arms, 10-speed AM double, PF30 spindle, S: 170mm, Others: 175mm
CHAINRINGS: 36/24, w/ alloy guard
BOTTOM BRACKET: SRAM PF30, OS press-in bearings, sealed cartridge
PEDALS: Upgraded - Shimano XTR
RIMS: Roval 26, alloy disc, 21mm internal width, 32h
FRONT HUB: Specialized Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 32h
REAR HUB: Specialized Hi Lo disc, 4x-sealed cartridge bearings, 12mm thru-axle, 142mm spacing, 32h
SPOKES: DT Industry Stainless, 3X front/rear 2.0mm
FRONT TYRE: Specialized Butcher Control, 2Bliss Ready, 26x2.3", foldable aramid bead, 60TPI
REAR TYRE: Specialized Purgatory Control, 2Bliss Ready, 26x2.3", foldable aramid bead, dual-compound, 60 TPI
INNER TUBES
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
Upgraded - Prologo Nago Evo X10
SEATPOST: Specialized Command Post BlackLite, 3-position, adjustable height w/ air spring, remote operated, single bolt head, 30.9mm, S: 100mm, Others: 125mm travel
SEAT BINDER: Command Post, 7050 hard anodized alloy, single bolt, 34.9mm
The formula brakes kept losing pressure so I upgraded them to XT's, and the stock Specialized grips were too thin for my preference so i put some thick race face ones on there. I also put my prologo saddle from my previous bike for comfort.
Given Specialized use a lot of custom/stock SRAM components it's hard to find the weights online to know what is worth upgrading? Does anyone know the weights for any of these stock components?
So, where will I get the most bang for my buck? I'm thinking in order of weight savings:
Wheels - Preferably something UST ready
Crankset - Not sure what to aim for with weight here? The stock has an alloy bash guard which im sure weighs it down. I've never bought a new crankset before, will any BB30 set be compatible with the SRAM PF30?
Handlebars - I enjoy the 750 mm wide bar. Wouldn't want to go much shorter than 700 mm
Stem - The stock one is short, like 50 mm
Any suggestions? Please give weights, or advise of what kind of weights you think I should be aiming for as i look around online. Also the bike is full black, with some red highlights so anything matching that colour scheme would be appreciated
Cheers
There are no new unread posts for this topic. Tarmac comp disc weight
Claudio
Thu Dec 14, 2017 3:26 pm
dcorn View the latest post
There are no new unread posts for this topic. 2017 Ruby Comp Upgrade (Di2)
century
Mon Apr 17, 2017 10:12 pm
century View the latest post
There are no new unread posts for this topic. Michelin Comp, killing sidewalls!
PLuKE
16
1511
Sun Jul 16, 2017 8:43 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Micheline power comp non-roundness??
in Everything wheels
Delorre
Tue Apr 18, 2017 6:48 pm
Delorre View the latest post
There are no new unread posts for this topic. Boardman Road Comp Frame Fork Headset Weight
kordis1
Sun Jul 16, 2017 9:37 am
kordis1 View the latest post
Users browsing this forum: No registered users and 8 guests
