It is currently Wed Apr 26, 2017 11:30 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Thu Jun 12, 2014 7:04 am
devinci wrote:
I actually have a set of 26 aspen tires, the side knobs are not that agressive at all, it is a fast tire.
How do they run in terms of Bag / Width? I've heard the 29" version are quite high volume, but haven't heard much about the 26".
I am worried, as I got some 2.1" high rollers years ago that were more like 1.7" wide, low profile things! :noidea:
Alot of people in Aus sware by the RoRo/RaRa or even NN/RaRa combionations, the other half of the population are either on Maxxis Ikons, Crossmarks (rubbish) or Conti Race Kings. Our trails for the most part are dry and rocky, typically.
My Training & Racing Blog -->http://mountainbikemediocrity.wordpress.com
Fuelled by --> http://www.pro4mance.com.au
PostPosted: Thu Jun 12, 2014 12:13 pm
they run smaller then Ikon. The sidewall are also fragile.
PostPosted: Fri Jun 13, 2014 12:20 pm
Have you considered Bontrager tyres?
I had dismissed them as the tread patterns were very 1990's but they've been updated and look rather nice.
I have XR2 Team Issue (rear) and XR3 Team Issue (front) for my all round, ride anywhere wheelset. I think a pair of XR2's or XR1 (rear), XR2 (front) could be great for racing.
Pros:
+ Grippiest rubber compound of the big players (found Schwalbe and Maxxis rubber to be a bit hard and plasticy and lacked traction on slick rocks and roots that litter courses even when the ground is otherwise dry)
+ Very robust sidewalls (happily ride all day in the rocks of the Welsh mountains without worry)
+ Robust rubber around the tread (most XC tyres still have thin rubber around the tread even in reinforced versions which reinforce the sidewall only- no help at all when you get cuts and thorns going in around the tread area!)
+ Fast rolling (XR2 especially)
+ Go up tubeless first time, even with a hand pump, without putting a tube in first!
+ Super easy to seal tubeless (hold air perfectly fine without sealant)
+ 2.2 is the smallest size for most tyres so gives a pretty reasonable air volume
Cons:
- Potentially a touch expensive
- That grippy compound will wear quicker than more "plastic" tyres
- They aren't the lightest. XR2 2.2 Team Issue (26 inch) were 564g average (580g claimed). I consider this the upper limit of acceptable for a race tyre but the trade off is awesome grip, tacky compound, super robust fit and forget tyres.
Some stuff to consider maybe? :)
PostPosted: Mon Jun 16, 2014 8:51 pm
To continue this thread. Are there any other options out there for a racing tire with good cornering capabilities, low rolling resistance and puncture protection for dry conditions?
Currently I'm using Geax Aka 29x2,2 and it almost fits the bill, the only problem are the sharp rocks - I've cut the tire between the knobs close to the middle of the tire I 2 occasions, 2 races in a row.
I'm leaning towards Maxxis Ikon 3c MaxxSpeed Tubeless Ready eXo, but it's almost double the price as the Aka. I was looking also at Schwalbe RaRa/RoRo but the sidewalls seem too thin for me.
PostPosted: Mon Jun 23, 2014 2:12 pm
What's the thoughts on Continental X-king as a front tire for cornering in dry and semi-dry conditions?
PostPosted: Wed Jun 25, 2014 7:48 pm
Just only today tried it for the first time and.... Whoa! Even better than RoRo in terms of grip on soil and getting out of ruts. Perhaps because of more square profile. Have heard only good things of it's BC compound. So my thumb up to it.
PostPosted: Wed Jun 25, 2014 8:02 pm
I really disliked the RoRo. Far too easy to cut in the tread area, awful on slick roots or rocks, reasonable in mud but not amazing, awful in anything vaguely rocky. Far too limited use range so I'd definitely look towards a BC X-King on Bonty X2 personally... even the Ralph is preferable and a pretty decent tyre.
A tyre for dry and semi-dry conditions relies heavily on a good rubber compound IMO (BC and Bonty compound are noticeably better than Schwalbe here) as you'll never want to be using deeper treaded tyres in these conditions. The trade off is some weight gain over Schwalbe but personally I'd take the better compound and more robust casing any day.
PostPosted: Thu Jun 26, 2014 1:28 pm
I am now leaning toward the Nobby Nic snakeskin, bit more agressive but I think I need something that bites in the corners, at the expense of rolling resistance.
PostPosted: Fri Jun 27, 2014 2:49 am
The NN works well with with the RaRa on the back, infact I wish I had a Nobby Nic laying around for this weekends race, its going the be a wet one! :(
There are no new unread posts for this topic. 2013 Cannondale Supersix Evo Race Edition - widest tire
G6612
Sat Mar 18, 2017 12:12 pm
dmtevo View the latest post
There are no new unread posts for this topic. Wider is better? 23mm tire on 21c rim vs. 25mm tire on 15c rim
Beaver
Fri Jul 01, 2016 9:46 pm
crimsonbadger View the latest post
There are no new unread posts for this topic. Trainer tire (solid tire?)
in Training
mvcap
19
1242
Mon Jan 16, 2017 7:41 pm
PMC View the latest post
There are no new unread posts for this topic. Which tire would you go for?
wheelsONfire
Fri May 27, 2016 7:30 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. CX and gravel tire
wheelzqc
39
2411
Wed Nov 02, 2016 6:22 am
PARTIZAN View the latest post
Users browsing this forum: Baidu [Spider] and 5 guests
