It is currently Sat Oct 21, 2017 11:37 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Yeti ARC carbon
PostPosted: Tue May 13, 2014 9:00 pm
Hey all,
Do you know if i can run the rear brake hose through the front derailleur routing through the down tube to clean up the looks when running 1x10/1x11?
Additionally, any thoughts on the arc c? i just can't get enough of that turquoise!
Thanks
 Post subject: Re: Yeti ARC carbon
PostPosted: Tue May 13, 2014 10:46 pm
I don't see why not, but you'll have to disconnect the hose then re connect it, but if you're comfortable doing that then it should be fine!
PostPosted: Wed May 14, 2014 8:11 am
i reckon my LBS is comfortable doing that! haha
Thanks!
PostPosted: Wed May 14, 2014 11:17 am
Hahahaha, very true! I want pictures when it's done, then I'll see what I can do on my Giant!
PostPosted: Thu May 15, 2014 8:41 pm
You'll have to drill out the stops to pass the hydraulic line (rather than just a cable with no housing). The other thing is that you'll still have the riveted on hose guides along the down tube that are meant for the brake line... Otherwise it'd definitely be a clean look!
Rise Bikes
Wilier Cento1SR Disc
There are no new unread posts for this topic. Attachment(s) My first MTB weight weenie Build help (Yeti SB5)
in MTB
Baller2011
19
2437
Fri Aug 11, 2017 4:35 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. Leather top vs. Carbon Fiber saddles (SMP Forma vs. Carbon Lite)
dgeesaman
Thu Aug 31, 2017 11:52 am
kgt View the latest post
There are no new unread posts for this topic. Attachment(s) New Saddle: Selle Italia Carbonio Flow vs San Marco Aspide Carbon vs San Marco Mantra Carbon
3Pio
33
2047
Wed Sep 13, 2017 6:08 am
3Pio View the latest post
There are no new unread posts for this topic. Is carbon lugged dead? Have modern monocoque frames usurped carbon lugged frames outside of just weight?
tranzformer
Sat Jul 22, 2017 4:14 pm
spartacus View the latest post
There are no new unread posts for this topic. Carbon-ti X-hub
in MTB
long19000
Sun Apr 23, 2017 1:07 am
jemima View the latest post
Users browsing this forum: No registered users and 5 guests
