It is currently Fri Jan 19, 2018 3:10 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Wed Apr 09, 2014 4:59 pm
The racer from the LBS has his at 20lbs on the XL frame, with xtr 1x10, and light but not massively fancy parts
PostPosted: Fri Jul 04, 2014 2:50 am
seismic,
any updates? What did you end up getting?
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Tue Aug 12, 2014 1:29 am
I'm curious as a well...please post an update with pics!
PostPosted: Wed Aug 13, 2014 2:54 pm
Well, I never found what I was looking for. I contacted Appleman and Crumpton. Crumpton never replied me so I gave up on this option. Appleman was very fast in responding and a pleasure to speak with. Unfortunately I was not able to get a frame down to the weight I wanted, so I gave up on this option as well. The only frame I managed to identify which was light enough was Open Cycles. Unfortunately I have decided against an Open frame (at least for now) as some of the feedback I have received say that the frames are quite soft. So, - unfortunately - for now, I am still on my old Flash. With the combination of a relatively acceptable weight and reasonable stiffness of the Flash, for now this seems to be the best solution. I do however hope to find something lighter way forward.
PostPosted: Sun Aug 24, 2014 7:59 pm
Seismic,
In spring I had exactly the same situation as you do now. I was riding my lovely 26" Cannondale Flash Carbon HiMod and wanting to switch to a light 29". I finally decided to build my bike on an Open 1.0 frame and have no regrets so far. I built mine with Lefty, XX1 and Industry 9 wheels. Handles very well and not soft. Actually the best bike I have ridden during my 20-year career on hardtails. So I would highly recommend to consider this frame. I am also 185 tall and riding size L. And if you have any specific questions about the frame and its stiffness, both Gerard and Andy from OpenCycle are very helpful. Just drop them an e-mail.
PostPosted: Mon Aug 25, 2014 11:05 am
Sounds good. Any pics and weight?
PostPosted: Mon Aug 25, 2014 2:22 pm
You can find a pic and full spec on Open owners' showcase: http://opencycle.com/owners-showcase/sliver-by-silver
Weight is 8,3 kgs but you can easily cut this by around 200 grams as my Thunder Burts came in at 520 and 530 grams respectively (claimed weight is 435 grams). The upside was that they were very easy to set up tubeless and I have had no issues with them during the season.
PostPosted: Mon Aug 25, 2014 2:27 pm
Looks good.
PostPosted: Mon Aug 25, 2014 3:43 pm
Thanks! If money is no object, they now have a frame called One, made together with AX Lightness and claimed to be stiffer that the 1.0. Anyway, as different riders have different needs, I recommend to contact them directly.
PostPosted: Mon Aug 25, 2014 4:16 pm
I will keep Open in the back of my mind as a potential option. They do have some interesting designs - interested in seeing how they will develop.
PostPosted: Mon Aug 25, 2014 8:07 pm
What did you get at the end?? I was checking this thread and it seems the new Open ONE is what you were looking for
PostPosted: Tue Aug 26, 2014 11:47 am
Open's head tube angle of 72 degrees is steeper than anything else that I know of wrt. 29er hardtails. The new Cannondale F-Si has a head tube angle of 69.5 degrees (vs. 71 for the F29). With other things being equal, a bike with a slacker head tube should be more stable on the descents...
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
There are no new unread posts for this topic. Between frame sizes - : Going larger frame vs going smaller frame
jeffy
16
1756
Sun Jul 09, 2017 11:03 pm
sooni View the latest post
There are no new unread posts for this topic. Hi-Mod frame vs non-himod ? Different frame quality ?
[ Go to page: 1 2 3 4 ]
destinationwarmth
49
7842
Sun Apr 16, 2017 7:58 pm
Hexsense View the latest post
There are no new unread posts for this topic. Sram Red BB386 Crankset with BB386 Bottom Bracket in BB386 Frame: Small Chainring touches Frame
jbattermann
Sun Jul 23, 2017 5:06 am
KCookie View the latest post
There are no new unread posts for this topic. Fuji SL frame, Transonic Elite frame, or Transonic 1.3 (all are 2017)?
BigPoser
Wed Feb 08, 2017 4:53 am
BigPoser View the latest post
There are no new unread posts for this topic. One frame that does it all
tarmackev
23
2739
Thu Apr 06, 2017 11:21 am
CarlosFerreiro View the latest post
Users browsing this forum: No registered users and 9 guests
