It is currently Sun Dec 17, 2017 5:43 am
PostPosted: Sun Mar 23, 2014 2:38 pm
It is my understanding that if I get a 9mm QR front dt swiss 240 6 bolts hub and rear 10x135 dt swiss 240 6 bolts hubs, that I can easily convert them to 15x100 front and 12x142 rear without much $$ being spent, am I correct?
PostPosted: Sun Mar 23, 2014 4:08 pm
DT doesn't make a front conversion from 9mm 6-bolt to 15mm, unless you buy the bigger and heavier DT 240 Oversize hub that also supports 20mm.
But one company makes a 15mm kit for the regular 9mm 6-bolt hub:
http://www.wmsracing.com/wmsweb/AXL15-W ... -disc.html
PostPosted: Sun Mar 23, 2014 4:33 pm
So if I get either the 190 or 240 in qr and centerlock, I will be able to convert them to 15mm and 12x142?
PostPosted: Sun Mar 23, 2014 5:17 pm
Incase there is no difference between 190 and 180, at least both are centerlock, you should be able to convert the rear to 142. Same goes with 240.
For 15mm front you would need either dt-swiss fifteen front hub or wmsracing conversion kit, not sure if it works also with 190 &180 front hubs, ask them.
http://www.wmsracing.com/wmsweb/AXL15C-WMS-15mm-Axle-Conversion-kit-DT-Swiss-240-front-QR-hub-center-lock-disc.html
http://www.dtswiss.com/Resources/Support/TECH-SPECS/Axle-convertion-kits.pdf
PostPosted: Fri Mar 28, 2014 1:07 am
Just to make sure, I am about to get the following:
dt swiss 240 15mm centerlock
dt swiss 240 10x135 centerlock rear hub
The front is good as it is already 15mm. Can I easily convert the rear one to 12x142?
Centerlock looks lighter too!
PostPosted: Sat Mar 29, 2014 3:07 pm
Shop Wrench
You can easily switch the axle and end caps on that hub to go 12x142
PostPosted: Sat Mar 29, 2014 9:36 pm
thanks!
Will shimano lockrings fit both thru axle configuration to secure the disc?
PostPosted: Mon Mar 31, 2014 3:05 am
Shop Wrench
You will need the 15/20mm lockring for the front hub. It has a larger ID and uses a hollow tech outboard bb tool to tighten instead of the standard cassette tool you would use on the rear.
PostPosted: Mon Mar 31, 2014 12:07 pm
Thank you! :)
PostPosted: Mon Apr 14, 2014 12:34 am
just so I don't do any mistake, if I am to convert a 10x135 centerlock dt swiss 240 to a 12x142 one, this is what I need right?
http://www.jensonusa.com/DT-Swiss-240-1 ... ersion-Kit
my hubs are the white logos ones, my rockshox maxle fits through it when I remove both end caps.
thanks
There are no new unread posts for this topic. 1x conversion
illlili
Tue Sep 26, 2017 12:05 am
bm0p700f View the latest post
There are no new unread posts for this topic. 404 tubular 10 speed conversion
martfarg39
Thu Jan 12, 2017 3:13 am
GonaSovereign View the latest post
There are no new unread posts for this topic. Fulcrum freehub conversion
in Everything wheels
Tricky1
Wed Oct 25, 2017 11:57 pm
Tricky1 View the latest post
There are no new unread posts for this topic. DTswiss 240 10spd to 11spd conversion
Timujin
15
960
Mon Jun 05, 2017 10:20 am
Timujin View the latest post
There are no new unread posts for this topic. Bora One 50's clincher tubeless conversion
Tommo
Sun Aug 06, 2017 12:17 pm
Tommo View the latest post
Users browsing this forum: No registered users and 3 guests
