It is currently Sun Jan 21, 2018 10:17 am
Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Tue Mar 18, 2014 5:07 pm
Not being able to use maxxis tires would be a pita.
Im not sure how they would not work though, using some tape and a compressor...
LB rims, carbonality rims... sounds about similar to me
PostPosted: Wed Mar 19, 2014 3:43 pm
I would stick with the AM Classic hubs. Industry9 are heavier, and their freewheel mechanism has a lot of drag. Get some of the higher end enduro bearings for your am classic hubs (if your current ones are worn), I got some of the angular contacts in my am classics just now and they feel a little better than stock. I also love the steel clips am classic has on their free hub, i9's have problems with teeth digging in.
PostPosted: Wed Mar 19, 2014 5:13 pm
Good informations, thanks for this.
Will keep thinking all of this but LB/carbonality carbon rims on 28h am classic hubs and cx ray sounds pretty good so far.
Though I may need to keep my current stans crest build if I dont sell my bike!
PostPosted: Thu Mar 20, 2014 9:19 am
Anyone had any failures with the Chinese rims?
PostPosted: Sat Apr 05, 2014 3:43 pm
I9 hubs are great. I had a set of the older ones and never had an issue. Very quick engagement, beautiful machining and anodizing, only downside was weight.
This week I built up a new set of wheels - the new and much lighter I9 Torch hubs (15mm, 142mm) with LB 33mm hookless 26" rims and 32 Pillar Xtra spokes. 1525g for the set. These will be bomb-proof.
While I9 uses an aluminum cassette body with no steel clips like the AC has, the aluminum is much harder than what I have seen on other hubs. Haven't had any gouging issues, which I did on previous gen AC, White Industries, etc.
Unless you are going to go for crazy light hubs I don't see how I9 Torch can be beat.
PostPosted: Sun Apr 06, 2014 1:21 am
well, thanks guys for the comments.
I managed to get my hands on centerlock dt swiss 240 hubs. They will be built on stans crest and dt revo spokes. Not crazy light, but should be light enough.
PostPosted: Sun Apr 06, 2014 12:36 pm
Bladed spokes will not be any stiffer, save your money.
I've got LB hookless 29er with AM classic 32/32 with revolutions, they're 1370g, very nice wheelset. I use Schwalbe TLR tyres - needed two turns of Gorilla tape, as tyres were too baggy with one, but they go up and seal perfectly with a track pump.
PostPosted: Sat Apr 19, 2014 8:25 am
Hi All, I'm looking to lace up some carbon race wheels using either LB or Carbonality rims for my Scalpel 2 29r.
In my birthday suit I'm about 80kg, but have found my fears about the Crest rims have come to pass and they badly need truing. Tried to do it today butgot nowhere.
Some of the trails I ride are moderately technical - St Ives singletrack, Manly Dam, Ourimbah (NSW Australia) with blue and occasional black sections probably being the upper limit of what I tackle on this bike. For general riding/training I will probably swap to Arch EX in the near future.
I was thinking the 27mm wide hookless LB rims or the Ti-wire reinforced Carbonality, but I'm favouring the LB rims.
Opinions on this choice would be welcome, and also on the number of spokes. I was thinking with the stiffer rims, 28H would be realistic for race rims. Or should I stick with 32H? Bladed or regular spokes?
Thanks for your help.
PostPosted: Fri Apr 25, 2014 5:24 pm
For my money (having used CX-Rays and Aerolites) I'd just get Revolutions. If you snap a lot of spokes consider bladed, but personally I found that I just broke nipples instead of spokes. Never broken a Revolution anyway.
Personally I just got 32H, 28 limits your choice of hubs significantly and saves virtually no weight, I just wouldn't bother. YMMV.
Continue to be impressed with the LB hookless rims though, generally running about 23-25psi in 2.25" Rons on mine and they're great, way stiffer than the 26" Podium MMXs I had on my last bike.
PostPosted: Thu May 29, 2014 1:53 am
I'm in the same boat as the OP, however I have a set of Mavic Crossmax SLR's as my everyday wheels.
They are super reliable and bombproof, but I'd love something lighter for racing.
Was thinking about some LB rims, but don't know what to use for hubs.
I'm using 15mm front and 12x142 rear through axles.
PostPosted: Thu May 29, 2014 1:59 am
how about tune king and kong? http://www.starbike.com/en/brands/tune/
or at the cheaper end of the scale, BHS has some slightly heavier chinese hubs available in 15 and 145 axles (162g / 268g f/r from memory)
PostPosted: Thu May 29, 2014 2:17 am
While they would be amazing, they are probably a bit more than I'd like to throw at hubs.
PostPosted: Thu May 29, 2014 4:39 am
Have you thought about a complete build from LB? Novatec D771SB/D772SB are great hubs for the $$$ and most people on MTBR seem to have been happy with the build quality of the wheels...
PostPosted: Thu May 29, 2014 7:27 am
Yes, Novatec D771/772 hubs and Sapim Delta spokes are good components for a wheels, with them, i think a XC 29" wheels can less 1450g. i heard of MTBR too, It seems Peter from XMIPLAY sold this light 29" wheels very well, get a high reputations in MTBR.com.
web: www.xmcarbonspeed.com
Email: bellajian@foxmail.com
Skype: bellajian1988
PostPosted: Thu May 29, 2014 11:25 pm
I would go with DT Swiss 240 28 spoke hubs with DT competition straight pull spokes laced to rims of your choice. I have just done a road bike disc build with these hubs and spokes on carbon rims as I see no reason given the stiffnes why they would not work with suitable rims for MTB.
D711/D712 hubs are pretty good too and come in 28H drillings for J-bend spokes. I would be tempted by FRM rims myself do not know the availability in Canada.
www.thecycleclinic.co.uk
There are no new unread posts for this topic. Light rider, need light wheels, light wallet?
in Everything wheels
eyedrop
Fri Mar 03, 2017 10:28 am
Multebear View the latest post
There are no new unread posts for this topic. Custom light cassette from Spécialités TA, anyone ?
LouisN
7
863
Sat Sep 09, 2017 11:40 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Which light-bicycle.com tubular rim for CX disc race wheelset?
savechief
Fri Jul 14, 2017 5:18 pm
There are no new unread posts for this topic. Custom Ti Frame and deep CF wheels
Phill P
Wed May 31, 2017 8:51 am
michel2 View the latest post
There are no new unread posts for this topic. Alloy Race Wheels
thedonnydino
9
1329
Sat Jun 17, 2017 6:06 am
istigatrice View the latest post
Users browsing this forum: No registered users and 12 guests
cron
