It is currently Fri Jun 23, 2017 11:16 pm
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Fri Mar 14, 2014 12:47 am
This might be the wrong question to ask....I am sure the debate is a HUGE one.
I had purchased a race bike from a friend of mine...mostly for the frame as I was going to re build it. I am an Old school biker, and have never, never, never, messed with a tubeless tire or system of any sort.
So anyway, I had a flat, and opened up the tire, excepting to replace a tube, but to my horror the worst rancid smell ever hit me, I started throwing up all over the place and was ready to chuck the whole damn wheel in the trash. Reluctantly, I opened up the rear only to find the same exact thing. I threw away the tires as they were the worst smelling things I have ever smelled in my entire life, went to my LBS bought a new set of tires and a set of Bontrager tubes that weigh 197 grams a piece, and was good to go.....So, what's all the hype? Is there really a huge advantage? If so, what are they? What is the best systems to use? Is there a method that's better than another, how often do you change the chemicals out and so on....sorry, I know its a lot.....but anyway? :noidea:
Thanks.
A Pile of Tile
Artistic Tile Inlay
http://youtu.be/9SctEhBljqY
01 Gary Fisher Sugar 1, 98 Schwinn Mesa GSX, 04 Ventana El Chamuco, 07 Navara Bliss
PostPosted: Fri Mar 14, 2014 1:42 am
is the smell thing a joke?
Many advantages, one of which you pretty much nailed with tubes at 197g each...
Other then that, possibility to ride low psi for added grip and comfort. The comfort and traction is a huge difference, for me anyway
PostPosted: Fri Mar 14, 2014 1:47 am
http://projecthree.blogspot.com/2011/08 ... -cons.html
viewtopic.php?f=1&t=85633
PostPosted: Fri Mar 14, 2014 1:52 am
No, no joke. I actually took them to the LBS...who said the sealant had rotted? I guess the bike had sat for a while.
What kind of PSI are you using?...I know it varies...
A Pile of Tile
Artistic Tile Inlay
PostPosted: Fri Mar 14, 2014 2:08 am
project3 wrote:
http://projecthree.blogspot.com/2011/08/tubeless-pros-and-cons.html
+1
:thumbup:
Makes a lot of sense.
A Pile of Tile
Artistic Tile Inlay
PostPosted: Fri Mar 14, 2014 10:26 am
..try eclipse tube :)
..little bit expensive,but a very light...if you want to save weight,the best solution,
..but for riding and a puncture protection tubeless rules :)
http://www.eclipse.ch/new/Tubes.html
BE a bike raider ,NOT a net surfer!
PostPosted: Fri Mar 14, 2014 1:29 pm
I typically ride 19psi on my Ikon 2.2 x 29 on my hardtail at 68kg. I would not say im not agressive rider. Fairly agressive but not taking useless risks.
PostPosted: Fri Mar 14, 2014 9:46 pm
I wouldn't say there is too much debate as most people will run tubeless for XC. Low tyre pressure without constant pinch flats and more resistance to punctures from thorns as the sealant fills the hole. Actually, it is remarkable what the sealant will fill. Dropping around 150-200g is nice too. Only the DH guys tend to run tubes or tubes and sealant. I'm not sure 100% sure why- perhaps related to burping the tyres at the crazy speeds they hit things at.
PostPosted: Sat Mar 15, 2014 2:46 am
I am running Crossmarks 2.1 on an older set of Crossmax UST rims at about 40psi, lots of fast single track, and never really had a real issue. Would like to give it a try, but I guess I need to buy selant, valves and rims strips then?
I ran an Ikon on the Front and a Crossmark on the rear, but recently changed due to a deal on Crossmarks.
A Pile of Tile
Artistic Tile Inlay
PostPosted: Sat Mar 15, 2014 10:23 am
I used to run 40 psi. In the 90s. When it was fashionable. Unless you are well over 100 kilos, there is no need for pressures that high with tubeless.
I now weigh 20+ kilos more, ride far harder and less carefully and run about 25psi, haven't had a puncture (snake bite or otherwise) for 3 years. Last puncture resulted in a tyre going to the bin (inch long cut through the tread) after I rode over the broken edge of a smashed roof tile.
It's really a no brainer to run tubeless now. You can get a complete stans kit (tape, sealant, strips) for about 35 quid iirc. All being well, you'll never need another tube on that pair of wheels. Just swap the tyres when they are worn out and add some sealant.
You don't need special tyres or special rims, just need to read the instructions.
PostPosted: Sun Mar 16, 2014 10:02 am
tubeless for sure. Who wants to puncture a heavy tube? One thing less that can break. Saving weight compared to heavy tubes. Possible to ride low pressure like devinci without puncturing if you have great rims.
I'm using around 25 psi for my 27,5x2.0 tires
/jonas l
PostPosted: Thu Mar 20, 2014 9:21 am
Tubeless for racing! notubes rims make it easy
PostPosted: Thu Mar 20, 2014 10:34 am
Tubeless for everything.
We've only got one set of mtb wheels (out of 8 or 9 sets) still with tubes in, and that's only as I broke a rim strip.
And for the cross bikes, 5 sets of wheels, one with tubes. (The spare, spare, spare wheels)
There are no new unread posts for this topic. 80mm latex tubes
A2ON
Wed Jul 20, 2016 2:16 pm
A2ON View the latest post
There are no new unread posts for this topic. Typical air loss from latex inner tubes
in Everything wheels
nemeseri
Tue Sep 06, 2016 12:59 pm
PrimO View the latest post
There are no new unread posts for this topic. Butyl or latex tubes? Opinions please.
brucew
24
2273
Sun Dec 25, 2016 5:08 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. cannondale six13 2 carbon tubes worth
jobvisser
Wed Aug 17, 2016 3:03 pm
polaris View the latest post
There are no new unread posts for this topic. Who is running latex tubes on carbon clinchers?
RJKflyer
41
2517
Mon Mar 27, 2017 5:57 pm
Multebear View the latest post
Users browsing this forum: No registered users and 9 guests
