It is currently Thu Apr 27, 2017 6:17 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Mon Feb 17, 2014 2:16 pm
Hello All :D
Do any of you guys know how to perform the change float fluid in air chamber on a Factory Series 32 FLOAT 29 100 FIT CTD.
I have been searching the http://service.foxracingshox.com/consumers/index.htm for help but did not succeed.
Ciao
Esben
Speed of Lite
PostPosted: Mon Feb 17, 2014 6:01 pm
Release all the pressure at the valve and unscrew the nut. This gives you access to the air (spring) chamber at the top. Usually there is a minimal ammount of oil to lubricate the piston seals, 20 to 30ml of 10Wt oil according to Fox.
If you turn the fork upside down, the remaining oil will come out, just add with fresh one after that.
PostPosted: Mon Feb 17, 2014 8:22 pm
There is a good summary video here: http://www.mojo.co.uk/dustwiper.html
There are no new unread posts for this topic. Attachment(s) Monarch XX vs Fox Float DPS (remote lock)
in MTB
PanaRob
Thu Apr 13, 2017 8:30 am
Kristinka View the latest post
There are no new unread posts for this topic. Rockshox Lyrik RCT3 vs. Fox 36 Float Factory
in MTB
g_doraz
Mon Nov 07, 2016 4:00 pm
mattyNor View the latest post
There are no new unread posts for this topic. Need to change rings ?
banik69
Sat May 21, 2016 3:49 pm
addictR1 View the latest post
There are no new unread posts for this topic. Attachment(s) Change of plans
Nightshade
Mon Oct 24, 2016 6:43 am
TonyM View the latest post
There are no new unread posts for this topic. Change topics heading
in Test
AUOC1OC6
Mon Aug 29, 2016 3:36 pm
AUOC1OC6 View the latest post
Users browsing this forum: No registered users and 6 guests
