It is currently Sun Apr 23, 2017 1:31 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sun Feb 16, 2014 12:00 pm
what do folks think of the cut out type headset spacers? :noidea:
they must be the lightest available (apart from maybe the polycarbonate type) but I wouldn't use them as they do not look as neat and I would be worried, probably unecessaril,y that they would let water and muck into the headset bearings.
PostPosted: Sun Feb 16, 2014 12:05 pm
I use the Cane Creek AER Spacers on the weight weenie build, depending on the headset there is a risk of water getting in.
PostPosted: Sun Feb 16, 2014 4:11 pm
I use ones like this.
Light. Strong. Cheap. Pick one.
PostPosted: Sun Feb 16, 2014 8:04 pm
How about ones cut out longitudinally?
PostPosted: Mon Feb 17, 2014 11:43 am
I wouldn't be super keen to use the ones originally suggested but really like BBB Ultraspace carbon spacers. For all intents and purposes the same as a normal spacer (i.e. work the same and keep water out) but at a fraction of even a normal light carbon spacer. Cheap too!
PostPosted: Wed Feb 19, 2014 4:29 am
You're less worried about using a spacer like in your first post that appears to be pretty poor compared to a simple, perfectly functional delrin spacer? :|
Anyway, the actual AER spacers are good, but if you're after something that's filled in, POP make some light spacers, but Tune magnesium seem to be some of the lightest:
PostPosted: Wed Feb 19, 2014 4:44 am
I would be surprised if the milled out carbon spacers that myself and DanW posted were not the lightest spacers available.
PostPosted: Wed Feb 19, 2014 6:13 am
Well then, be surprised - Extralite delrin and POP aluminum are almost the same weight. Tune magnesium, Point1 and HiTeMP42 aluminum are lighter. But hey, we're arguing over a gram here... errr less than a gram.
PostPosted: Wed Feb 19, 2014 9:36 am
The BBB I posted are the lightest I could find and I did a lot of research on that. But as you say it is only a g or so depending on the amount of stack you use ;) The main draw for me is that the BBB are not only the lightest but £8 for a 40mm combo IIRC
PostPosted: Wed Feb 19, 2014 5:26 pm
How about some actual weights, taken at the same time using the same scale.
5mm:
Tune Magnesium: 1.3gr
Point1, 1.4 gr
Parts of Passion, 1.5gr
Extralite, 1.9gr
Cane Creek AER, 2.0gr
Kcnc hollow alloy, 2.6gr
Std carbon, 2.7gr
10mm:
Point1, 2.3gr
Tune Mag: 2.4gr
Parts of passion 3.1gr
Extralite, 3.4gr
Cane Creek Aer, 3.9gr
Std carbon, 4.2gr
Kcnc hollow alloy, 5.5gr
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Wed Feb 19, 2014 5:57 pm
meh... Don't believe you :wink:
Custom Rychtarski steel bike
Ridley X-ride 10
Custom Wittson Ti
PostPosted: Thu Feb 20, 2014 3:13 pm
No BBB carbon or FSA carbon.......
There are no new unread posts for this topic. Spacers for SRAM GXP team BB
leicaman
Mon Mar 13, 2017 4:21 pm
leicaman View the latest post
There are no new unread posts for this topic. Campagnolo Overtorque crank missing spacers?
svm
Sun Jun 05, 2016 6:53 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Specialized OSBB with S-Works Crankset spacers?
Alpine318is
Thu Apr 13, 2017 7:58 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Bor RR688 crankset w/ rotor 4630 bb-spacers?
reedplayer
Thu Aug 18, 2016 1:52 pm
reedplayer View the latest post
There are no new unread posts for this topic. Best Inflation Head For An Air Compressor
EvilEuro
7
561
Sat Jan 21, 2017 4:14 pm
Marin View the latest post
Users browsing this forum: No registered users and 5 guests
