It is currently Wed Jan 24, 2018 10:54 am
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: BB92 Options?
PostPosted: Thu Jan 23, 2014 5:27 am
Bit of a newbie question... I have taken delivery of an Ibis Mojo SL-R frame and I'm thinking about doing a lightweight-ish build. I understand it takes a BB92 bottom bracket. What are my BB and crank options? I've been riding SS for a few years, so I'm leaning towards 1x10 or 1x11.
Thoughts? And thanks in advance for your suggestions!
 Post subject: Re: BB92 Options?
PostPosted: Thu Jan 23, 2014 6:58 am
Raceface Next SL is in the price/weight category in its own league, with 1x10 or 11 setup well below 500 g. Ordered, but not yet received, so no first hand. See thread in this forum about Clavigulas as well. I have shimanos BB92 bottom bracket.
PostPosted: Thu Jan 23, 2014 3:26 pm
BB92 looks pretty versatile. Enduro makes a BB92 - BB30 adapter. Not sure how good it is, but might want to give it a look. http://www.enduroforkseals.com/id258.html
Enduro makes decent bearings, but I've found that the grease they use isn't very water resistant, and your bottle sweat will eventually destroy them. Your best bet is to remove the seal, flush out the bearing with a cleaner, then repack it with a better waterproof grease (I have been using marine grease, available at any fishing or trailer supply store). This applies to both the standard steel and ceramic bearings.
In terms of cranks, you'll be looking at any Shimano offering or a SRAM GXP crank, unless you use an adapter.
PostPosted: Fri Jan 24, 2014 2:32 am
Kinda... but don't confuse the issue, it's not a BB30 adapter. There is no way for a 'normal' BB30 crank to work in a BB92 shell (there are exceptions but they all require modification or 'non standard' parts eg: SiSL arms with NextSL or DrCannondale spindle).
Any cranks that work with 73mm, outboard bearing BB's will work with BB92 as the bearings are in the same place, but housed in plastic cups instead of threaded aluminum ones.
PostPosted: Thu Jan 30, 2014 7:33 pm
You know that you can use a BB92 RF bottom bracket and use any 24mm spindle crankset ?
http://www.pricepoint.com/Brand/Race-Fa ... racket.axd
Parlee Z3c
Independent Fabrication SSR // 953
Independent Fabrication Planet X
Knolly Chilcotin
PostPosted: Thu Jan 30, 2014 8:06 pm
For the SLR I would go RF Next SL with a spiderless chainring.
There are no new unread posts for this topic. Help installing DuraAce BB92-41 Bottom Bracket
apctjb
Fri Dec 08, 2017 4:23 pm
apctjb View the latest post
There are no new unread posts for this topic. Crank ideas for 2017 Scott Addict with BB92 PF
Johnny Rad
Tue Feb 14, 2017 5:42 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Frame Options Under ~$800
mrpillow
25
2527
Mon Jul 03, 2017 10:27 am
shinjiwoon View the latest post
There are no new unread posts for this topic. F10: Which headset top cap options are available?
TonyM
7
662
Sun Dec 31, 2017 11:02 pm
TonyM View the latest post
There are no new unread posts for this topic. 650Bx38c Options?
FreaK
9
748
Tue Oct 31, 2017 6:56 pm
UpFromOne View the latest post
Users browsing this forum: kx_1 and 3 guests
