It is currently Fri Dec 15, 2017 1:54 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Jan 16, 2014 12:26 am
I may get some shimano XTR m987 brakes, which apparently, are only i-spec B-type compatible.
I already have some shimano XTR i-spec shifters but im not sure they will fit the new brakes. I need to know if they will or not. I have attached 3 pictures, one of which shows the hardware that came with the shifters to attach to the brakes.
Anyone is sure it will fit i-spec b-type?
PostPosted: Thu Jan 16, 2014 7:59 am
The original I-Spec clamps won't work with the new I-Spec B mounts according to shimano. There may be some sort of work around, but officially it won't work. :noidea:
EDIT: the picture wasn't accurate, so I took it down. The only mix matching that will work is I-Spec B Shifters with I-Spec A brake levers.
PostPosted: Thu Jan 16, 2014 12:24 pm
So mine are i spec b? Therefore they will work with 987?
My blog: www.cyclingtrainingnuts.blogspot.ca
PostPosted: Thu Jan 16, 2014 7:47 pm
Oh sorry, yeah that will work, those are I spec b shifters. I apparently have no reading comprehension... For some reason I was under the impression that you had I spec a shifters, but looking back at the pictures, those are definitely I spec b.
PostPosted: Thu Jan 16, 2014 10:47 pm
yep, probem solved.
Ordered new brakes.... 987
There are no new unread posts for this topic. SRAM 11 speed 1x shifter compatibility
bobalou
Sat May 20, 2017 2:35 pm
silvalis View the latest post
There are no new unread posts for this topic. Campy Potenza Shifter compatibility
nthanach
9
988
Thu Jun 08, 2017 8:32 pm
kervelo View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano DI2 / R785 shifter woes....
BigCol
Thu Apr 20, 2017 11:06 pm
BigCol View the latest post
There are no new unread posts for this topic. modifying shimano 685 front shifter for 1x
simoncx
Tue Dec 05, 2017 12:06 am
simoncx View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano Compatibility
Valbrona
Mon Jan 02, 2017 10:55 pm
ooo View the latest post
Users browsing this forum: No registered users and 3 guests
