It is currently Mon Jan 16, 2017 11:06 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Thu Jan 09, 2014 12:35 am
2 questions here
1- Where can I find a very low stack headset cap such as the slam that stem ones? The slam that stem are not available anymore on their website.
2- When using Ti bolts in aluminium or steel socket, should I need anti seize paste? Will simple blue loctite do the trick in areas that are most stressed (brake calipers)?
thanks guys
PostPosted: Thu Jan 09, 2014 1:06 am
I've always used finish line ti prep where ti comes in contact with alum or steel, never had a problem but a little goes a long way.
PostPosted: Thu Jan 09, 2014 2:23 am
http://taticycles.com/
click on shop, search for 'bearing cover'.
Grover's Grumblings
Grover's Garage
PostPosted: Thu Jan 09, 2014 2:50 am
hey thanks
will check that out tomorrow, hopefully they will ship to Canada!
PostPosted: Thu Jan 09, 2014 10:52 pm
Ti-Prep is fine on things like lever clamp bolts that don't need to maintain a high torque but on higher torque stuff like caliper bolts, rotor bolts, etc then threadlock is much better. Same anti-corrosion benefits but less chance of a bolt working loose. I'd be inclined to say think of Ti-prep like a grease so if you wouldn't grease a bolt don't Ti-Prep it
PostPosted: Sun Jan 26, 2014 9:27 pm
well, the shop hasnt replied to my email asking if they would ship to Canada.
I will try to make a homemade headset cap setup, using thin spacers and a rubber seal
PostPosted: Sun Jan 26, 2014 10:27 pm
http://veloflyte.com/ultra_low_stack_height_carbon_fiber_integrated_headset_dust_shields
He posts here sometimes as well.
PostPosted: Sun Jan 26, 2014 10:58 pm
absoluteblack makes one that is similar to the Soul Kozak one....
http://www.absoluteblack.cc/top-cap.html
only 4g with bolt.
- AX Lightness Vial EVO D + DA9070 + Enve SES 2.2 tubeless with carbon hubs
- Parlee Altum + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Thu Mar 27, 2014 6:57 pm
AGW wrote:
Indeed I do. After 20 years as a mechanic and amateur racer, I try offer advice when I think it might be helpful.
PostPosted: Fri Mar 28, 2014 5:50 pm
I have a new in package slam that stem cap if you are having a hard time getting one.
devinci wrote:
2 questions here
thanks guys
PostPosted: Fri Mar 28, 2014 9:05 pm
I thought you guys would like to see how I sorted this...
viewtopic.php?f=10&t=121489&start=90
There are no new unread posts for this topic. Schmolke Carbon + Titanium bolts upgrade
njyeti
Wed Feb 03, 2016 4:27 am
njyeti View the latest post
There are no new unread posts for this topic. upcycling with titanium pivot bolts and turning rear caliper breaks into front.
Psyclebaz
Thu Aug 11, 2016 4:09 pm
Psyclebaz View the latest post
There are no new unread posts for this topic. lowest stack carbon saddle
InoxEPS
7
755
Tue Oct 18, 2016 1:36 pm
metabo View the latest post
There are no new unread posts for this topic. Different SPD pedals with 5mm stack height difference?
in MTB
motorthings
20
852
Sat Nov 05, 2016 1:40 am
TheKaiser View the latest post
There are no new unread posts for this topic. Stack and Reach For Mountain Bikes = BS
in Training
joeg26er
12
889
Thu Aug 11, 2016 7:44 pm
KWalker View the latest post
Users browsing this forum: No registered users and 4 guests
