It is currently Mon Jan 22, 2018 11:57 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Wed Jan 08, 2014 2:10 am
I know that Overend used the Spesh carbon crank on his SS Rockhopper a few years back...and from what I read...the older cranks were able to use a Vumaquad bottom bracket to run the crank.
I just noticed Overend using a Specialized carbon crank on a 2014 Crave. The Crave uses a standard threaded bottom bracket. Anyone know how it could have been installed...or it it just a standard Lightning crank that was re-labeled?
Thx
The first image,
http://www.specialized.com/us/en/bikes/ ... #in-action
PostPosted: Wed Jan 08, 2014 5:18 pm
For bsa bottom brackets there are plenty of cups available, that will allow 30mm axle. E13, Rotor, Race Face, THM, etc. S-works mtb cranks should fit in 68mm bb, not sure about 73mm, might be too wide.
PostPosted: Wed Jan 08, 2014 6:15 pm
It works on BSA 68mm threaded, but you need to make sure you have the MTB version with the 90.7mm spindle. The road version are to short. Use any of the 30mm threaded cups ( I use the Hive cups), remove all spacers between the frame and cups. On the non-DS I run one wave washer and it works excellent. You can save approx. 20 grams running the Lightning spider instead of the Specialized spider on the S-Works cranks.
This won't work on 73mm BB unless you make a Hirth spacer to go between the spindles.
PostPosted: Thu Jan 09, 2014 2:18 am
Thanks for the replys!
Specialized uses a 73mm BB. So Specialized used a hirth spacer on Overend's bike?
PostPosted: Thu Jan 09, 2014 3:29 pm
Other option could have been they just machined 2.5mm off from each side of the bb shell.
There are no new unread posts for this topic. FS: Specialized S Works FACT BB30/PF30 crank arms 172.5 $75
boots2000
Thu Nov 23, 2017 6:08 pm
boots2000 View the latest post
There are no new unread posts for this topic. Middle threaded hole for Sidi Shoes?
Cheers!
11
1229
Thu Jan 26, 2017 3:13 pm
duvivr6 View the latest post
There are no new unread posts for this topic. What part number ? Need Threaded Boost BB for SRAM Eagle cranks :)
in MTB
joeg26er
Wed May 24, 2017 5:28 pm
wpccrunner View the latest post
There are no new unread posts for this topic. Attachment(s) Fork Needed - straight, carbon, 1" threaded steerer - suggestions?
dadoflam08
12
755
Wed Jul 26, 2017 11:31 am
dadoflam08 View the latest post
There are no new unread posts for this topic. [SOLD} S-Works SRM 175mm with S-Works TT rings
muffinman
Tue Oct 31, 2017 11:41 pm
muffinman View the latest post
Users browsing this forum: No registered users and 7 guests
cron
