It is currently Fri Dec 15, 2017 12:17 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Tue Dec 31, 2013 2:18 pm
Hey guys. So I originally got a wheels manf bb30-24mm spindle bottom bracket. So it has the two C clips and the two bearings plus the two plastic adapter things. I now have a bb 30 crankset. I notice the sram bb30 bottom bracket is just 2 c clips, 2 bearings and then 2 black cap things. Made of metal by the looks of things. Do you know if I need these?
I notice wheels man sell a bb30 bb which is just the two 2 c clip and 2 bearings. And it's 15 grams lighter. I assume this is because it doesn't come with the end cap things? Doesn't show them in picture at least. So I am confused on if I can use what I have or if I need to purchase another BB to get the two cap things.
Anyone have any insight? Thanks.
PostPosted: Sat Jan 04, 2014 10:02 am
Anyone know if it's just like another seal to help stop grit getting in the bearings? Or being made of metal is it a plate thing to make sure the cranks are up against it and it makes the correct placement against the bearings to spin efficiently? Still can't figure out if it's needed or not.
PostPosted: Sat Jan 04, 2014 6:00 pm
The piece you are describing is a seal/barrier against dirt & grit getting at the bearings yes... sitting in between those pieces and your crank arms you should have a wavy washer on the drive side and possibly spacers... on the non-drive side you may have spacers... depends on your frame and chainline.
But otherwise to answer your question... you could do away with them but you'd a). need more spacers, and, b). your bearings would die a quicker death... so yes, use them.
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. Help me fix my CREAKING bb30 bottom bracket
jobvisser
33
2825
Wed Apr 05, 2017 2:11 am
glepore View the latest post
There are no new unread posts for this topic. What bottom bracket do I need
JScycle
Tue Oct 31, 2017 7:56 am
JScycle View the latest post
There are no new unread posts for this topic. Attachment(s) Bottom bracket 386 for Cipollini
MiddMan
11
907
Sat Jun 24, 2017 3:03 pm
Calnago View the latest post
There are no new unread posts for this topic. Bottom Bracket Drag
Ltoddokc
10
1482
Wed Oct 18, 2017 12:32 am
youngs_modulus View the latest post
Users browsing this forum: No registered users and 4 guests
