It is currently Sat Jan 20, 2018 8:30 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Fri Dec 13, 2013 7:36 am
I have a 2011 tapered, Reba XX 29 Dual Air with 9mmQR. I found a 2011 SID XX World Cup Dual Air lower, with 15mm TA. Can I swap the Reba XX internals directly into the SID WC? The lower leg cavity of the Reba is 57mm and the SID WC is 71mm. Can the Reba Dual Air chambers fit inside, or do I need to buy SID-specific ones? Also, does the XLoc Motion Control damper/lockout fit?
I know this is a long shot - but if anybody has done this conversion....I'd love to know about it. Thanks in advance.
PostPosted: Fri Dec 13, 2013 8:26 am
You won't be swapping internals at all will you? Either the REBA uppers fit into the SID lowers or not, first off measure stanchion diameter, if they are the same then try it, I did similar with some Manitous a while back and never had an issue, if it doesn't work, you'll find out soon enough and doing an upper swap will only take 10-15 minutes anyway (2 bolts to undo and do up!), it will take longer to research all the options!
PostPosted: Fri Dec 13, 2013 5:25 pm
The Reba XX stanchions are 32mm, exactly the same as SID XX WC. My concern is the length of the air chamber rods.
PostPosted: Sat Dec 14, 2013 11:28 am
So measure up as you go, make sure the uppers go through the bushings in the lowers fully at top out and go try.
What is the length difference between retaining bolt head at the bottom and wiper seal at the top?
There are no new unread posts for this topic. Attachment(s) reducing 15mm thru axle fork to 12mm
in MTB
spud
37
1624
Fri Jan 12, 2018 2:17 am
joejack951 View the latest post
There are no new unread posts for this topic. C60 disc - 15mm Hexlock, what is this?
superdx
Wed Nov 08, 2017 12:59 am
Disc0 View the latest post
There are no new unread posts for this topic. Thru axle adapter
markyboy
7
436
Wed Dec 13, 2017 12:42 pm
ms6073 View the latest post
There are no new unread posts for this topic. Mag 150 with Carbon Axle?
whydobearsxplod
Fri Sep 29, 2017 11:30 am
There are no new unread posts for this topic. BSA 68 support for 30[mm] crank axle
Shmitt
10
946
Sun May 07, 2017 1:13 pm
bikerjulio View the latest post
Users browsing this forum: No registered users and 7 guests
cron
