It is currently Tue Jan 16, 2018 7:00 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: Old School Weight Weenie
PostPosted: Thu Dec 05, 2013 10:14 pm
Hi, I'm new to this forum but I thought I'd share my WW journey. Last year I bought an older bike with no intention of ever being a WW. Boy was I wrong.
The bike is a 2003 Kona King Kikapu, 16.5". It was advertised at 21lbs which I thought was a bonus since this bike was immaculate. After bringing it home and throwing it on the scale I was sorely disappointed, 25.7lbs :shock:
This is when my journey began and I was bitten by the Weight Weenie bug! I was now on a mission to drop at least 4lbs...
This is how the Ad read:
Top of the line full XTR (not just the derailleur) Kona Kikapu. XTR cranks, XTR shifters, XTR brakes, XTR cog set, XTR front/rear derailleur, Race Face stem, Easton seat post, Mavic 317 rims, FOX TLT fork and FOX Float rear shock. We have a few handle bars if you want to swap too. As you can see from the pictures, it's in pristine shape, lady driven. Weighs about 21lbs
Here she is at 11657grams (25.7lbs) when I bought her.
Weight Weenie King Kikapu
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=121448
PostPosted: Fri Dec 06, 2013 3:49 am
So the first thing I decided to address was the heavy cockpit by swapping in some carbon components.
Before
After
PostPosted: Fri Dec 06, 2013 5:08 am
At this point she was down to 11258 grams (24.82lbs). Meh
Had to keep going...
Decided to try some lighter tires so I threw on some 2.25 Racing Ralph and dropped another pound, down to 10805 grams (23.82lbs)
Now I was on the hunt for lighter wheelset and found myself a set of ZTR Podium MMX and set them up tubeless with Hutchinson Piranha 2.0 and Ashima Ai2 160mm rotors.
Front wheel
Tires
This got the bike down to 10160 grams (22.4lbs) :D
PostPosted: Fri Dec 06, 2013 5:18 am
:welcome:
Nice documentation of your WW journey!
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Fri Dec 06, 2013 5:39 am
Thanks btompkins
PostPosted: Fri Dec 06, 2013 5:50 am
Next I figured I could lose a little weight if I found the right replacement for the Fox F80.
Hmmm maybe a Rock Shox Sid World Cup would do the trick...
And maybe a Dura Ace 12-27 cassette for good measure
So now I've hit my target weight at 21.7lbs. Why don't I feel satisfied?? :noidea:
PostPosted: Fri Dec 06, 2013 6:55 am
This is where I decide to address some smaller items.
Before
After
Full carbon saddle
Before
After
MT Zoom seat clamp
Before
After
Ness titanium QR skewers
Before
After
KMC X10SL
Woohoo! 21.0lbs
PostPosted: Fri Dec 06, 2013 8:22 am
The King Kikapu at this stage.
PostPosted: Fri Dec 06, 2013 8:25 am
Administrator
Super Sweet, How does 21LB translate into KG? Thanks.
{USERNAME} wrote:
PostPosted: Fri Dec 06, 2013 8:42 am
Anybody run Hutchinson Piranhas tubeless? Don't bother, it could be dangerous... BOOM
After this happened I read that it has happened to others as well. The bead fails!
PostPosted: Fri Dec 06, 2013 8:48 am
Hi Frankie B. 21lbs = 9.5kg
PostPosted: Fri Dec 06, 2013 9:18 am
After the blow out it was a good opportunity to get some lighter tires and maybe a lighter cassette.
Brings it down to 20.28lbs or 9200grams
Maxxis Maxxlite 285
Dura Ace 11-23
PostPosted: Fri Dec 06, 2013 6:18 pm
Sorry for posting in the wrong area of the forum...
My story will continue in the Gallery section eventually because 21lbs just isn't light enough :wink:
PostPosted: Fri Dec 06, 2013 8:28 pm
Another reason for tires to blow off the MXX rims is going over the max. recommended pressure. Happened to me while setting up the tire tubeless once.
You are cutting corners to cut the weight down fast, but it may hurt the functionality. Where and how you will use this bike is another story. It's a nice old school machine for sure!
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Fri Dec 06, 2013 9:38 pm
Thanks for the comments Chris.
It probably seems like a quick drop in weight but these changes having been ongoing since early 2012. And you're right I definitely wouldn't want to use any components that would hinder the overall functionality of the bike.
There are no new unread posts for this topic. Which cable system is the most weight weenie?
BigPoser
Sat Feb 11, 2017 3:19 am
danbjpa View the latest post
There are no new unread posts for this topic. focus weight weenie e-bike
spartan
Thu Jun 29, 2017 11:37 am
Marin View the latest post
There are no new unread posts for this topic. Weight weenie frame choice
[ Go to page: 1 2 3 4 5 ]
964Cup
64
8464
Wed Jul 19, 2017 2:31 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Attachment(s) My first MTB weight weenie Build help (Yeti SB5)
in MTB
Baller2011
19
3475
Fri Aug 11, 2017 4:35 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. Weight Weenie Showdown: Shimano Di2 vs. SRAM Force 1
Bhaalgorn
7
1038
Mon Jul 17, 2017 6:48 pm
justaute View the latest post
Users browsing this forum: liam7020 and 17 guests
cron
