Tune King / Kong hubs - opinions please!
cws196
by cws196
Seriously considering a set of these hubs because they're light, a bit different (!) and appears they can be serviced at home.
There seem to be a few horror stories about the freehubs (I'll be using an XX1 type), but I was told alot of the issues have been fixed in the last year or so.
What are previous/existing users opinions?
krzysiekmz
by krzysiekmz
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
cerro
by cerro
Used King/Kong with XX1 all season on a AMbike without any problems. Really satisfied.
But serviced at home? Pretty hard to get the body off without Tune's extractor but you're right about it else.
/jonas l
Sandal
by Sandal
i've never had a single issue with 3 or 4 sets of king/kong hubs from 2008 with tones of mud and kms on most of those. The Prince hub (rear) form 2009, howenver, failed in the freehub after 5 years of moderate use. i'd opt for Kong with rear hub therefore.
weight concerned = good, weight obsessed = bad!
spooky817
by spooky817
Hi There,
I've run king and kong and prince and princess on several bikes and they have been great. I would suggest that the issue Sandal from above had with the freewheel body failing has nothing to do with the hub being a princess rather than a kong. They both run the same freewheel bodies. (Although there is a Skyline freewheel body which is used on the Princess, but I would assume the additional machining that differentiates the Skyline freewheel body from the regular one was not the failure point).
Enjoy, they're great hubs ;-)
...make it lighter...
jooo
by jooo
Sandal wrote:i've never had a single issue with 3 or 4 sets of king/kong hubs from 2008 with tones of mud and kms on most of those. The Prince hub (rear) form 2009, howenver, failed in the freehub after 5 years of moderate use. i'd opt for Kong with rear hub therefore.
You know both hubs have had an almost complete redesign since then?
Sandal
by Sandal
yes, i know, they are different and still perfect. nevertheless, i'm cautios to try Prince again... :roll:
TheRookie
by TheRookie
Sandal wrote: with tones of mud
"Under the Moon of Love" perhaps?
