It is currently Sun Jan 22, 2017 6:58 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
 Post subject: Brakes?
PostPosted: Thu Nov 21, 2013 11:56 am
Hi Guys,
I am currently running Magura MT8, but I have to admit that it is not a nice brake. It is noisy, and (as from what I am being told) due to the material used to make the calliper, at bit of expansion is possible for the brake fluid, hence it is difficult to get a firm and consistent brake. The soft feeling in combination with inconsistent braking has now gotten the better of me. I am looking for something else. If we consider 200% WW, which alternatives do then exist in the market which can actually brake and perform in competition? The R1 is light, but has it own issues. Otherwise, things are getting heavy. I do recon that many MTBs will accept a bit of extra weight in order to get a good brake, but do we really not have a strong and consistent (but light weight) brake soon writing 2014?
The intended purpose is to build a competition worthy XC racer which I hopefully can push down in weight as far as possible.
Thank you for input.
Brgds
seismic
 Post subject: Re: Brakes?
PostPosted: Thu Nov 21, 2013 1:52 pm
I have been happy with my Formula R1, 2009 model. I have been running them since May 2009. Lightweight, powerful, modulation is good. If you take care of them (bleed them once a year with high quality DOT fluid and clean but do not lube the pistons when you change pads), you should not be disappointed.
Stefan
PostPosted: Thu Nov 21, 2013 3:50 pm
Hope X2? Fairly light, good modulation (very good), rebuildable, spares easy to come by.
XTR? (Or XT if on a budget?)
Whenever i've bought brakes in the last 5 or so years it's been either shimano, or hope (if the bank balance says yes).
They just work, and work, and work.
PostPosted: Thu Nov 21, 2013 4:06 pm
Hope and Shimano work indeed. You are right. But they are heavy. I am ok with shelling out some $$$ if I can find the right solution….not easy though :noidea:
PostPosted: Thu Nov 21, 2013 4:45 pm
XTR985 have ultimate performance/reliability/build quality and a reasonable weight.
If XTR987 is as great as 985 with 80g less per pair, maybe thats what your are looking after.
unfortunately I have yet to find and serious review from XTR987.
Cheers
PostPosted: Thu Nov 21, 2013 5:45 pm
The XTR M987's aren't out yet, should be available in early 2014, so don't expect many reviews for a while!
Also, I'd hardly call the Hopes heavy, only mildly heavier than the R1's.
PostPosted: Thu Nov 21, 2013 6:52 pm
Hope X2 race is probably your best bet. XTR M985 are a bit heavy, but have ultimate performance. If M987 maintain performance then they will be the premier option for all mountain bikers, WW included. Ashima PCB are pretty cheap and are very light but apparently have a 'squishy' feel. Have you considered Avid? While they have a bad rep, SRAM brakes have really improved with the 2013 models and are very competitive on the weight side.
This should give you an indication of power vs weight...
http://www.bikeradar.com/mtb/gear/artic ... kes-24345/
PostPosted: Thu Nov 21, 2013 6:54 pm
The hopes are light and beautifully made, but I found them a bit lacking in power (considering 160mm rotors on a 26" bike).
I have MT8s on my bike and like them now after using a modified bleeding procedure. Out of the box I found them spongy with too much lever travel. As part of the bleeding procedure I ground the transportation device/spacer down by 0.75mm, and as the last step before buttoning up the caliper (lever already buttoned up) I push fluid into the caliper from the bleed syringe. The combination of the above reduced lever throw and improved feel greatly, and I don't have any issue with pad rubbing. I think it's worth at least giving these things a try before you ditch an expensive set of brakes.
Enjoying my Funk
PostPosted: Thu Nov 21, 2013 7:00 pm
Funny my experience of the hopes considering the bikeradar article seems to show them having as good power as any other. :noidea:
Something seems fishy with that article though, at least in terms of weights: it has the Magura MT6 being lighter than MT8 which is obviously wrong. Also seems odd that the MT4&6 would have the same power as each other, but the MT8 10% less. As far as I know the callipers are the same between MT8 and MT6.
Enjoying my Funk
PostPosted: Thu Nov 21, 2013 7:07 pm
Yeah, I find the hopes to lack initial bite. Can be confused with insufficient power. Though I can lock either wheel with one finger.
The benefit of the "lack of bite" is that I have enough feel through the lever that I can brake on very slippy or loose surfaces (roots rocks etc) with out locking the wheel. Couldn't do that with the xts I had before
PostPosted: Thu Nov 21, 2013 7:20 pm
I seem to remember reading that Hope modified the pivot point on the X2's to give it more power in 2012 (?), so I guess how powerful they were depends on if you used the Race X2's or the Race evo X2's.
PostPosted: Thu Nov 21, 2013 7:31 pm
Good info Colin: I have a set of 2009 brakes, the Race X2. Guess that explains it!
Enjoying my Funk
PostPosted: Fri Nov 22, 2013 12:53 am
The new XTR 987 are available in some countries yet, a WW member posted pictures of his, he is from Asia
PostPosted: Fri Nov 22, 2013 5:19 pm
I would go XTR, best brake I ever used and worth the extra weight they have.
PostPosted: Fri Nov 22, 2013 5:41 pm
The Race X2's are powerful enough if you are a light rider... but they struggled to stop me at 180lbs.
They aren't to everyones tastes but personally I like Marta SL's... however the XTR brakes are excellent, wont go wrong with them.
There are no new unread posts for this topic. EE-brakes
bruno2000
25
2424
Thu Jun 23, 2016 2:38 am
2lo8 View the latest post
There are no new unread posts for this topic. Brakes
goldielox
10
866
Sat May 14, 2016 7:11 am
Synnove View the latest post
bruno2000
Fri Jun 17, 2016 5:35 pm
Sim0n0 View the latest post
There are no new unread posts for this topic. AX orion brakes help.
xena
Tue Feb 02, 2016 3:11 pm
xena View the latest post
There are no new unread posts for this topic. Sram Red brakes
gtinut
Tue Apr 26, 2016 5:53 am
tinozee View the latest post
Users browsing this forum: No registered users and 4 guests
