Wide range 10 speed cassette options
Getter
by Getter
Looks like Wolf Tooth Components are jumping on the "wide range" bandwagon too.
Leonardi's 9-42 cassette from their Facebook page. Looks like a real nice piece of work.
Getter
by Getter
Quick follow up. Went to Interbike and saw a company called Response. Ordered a three of their cassettes. Installed one on my 29er. Replaced the OneUp 42T and Wolf Tooth 16T add ons.
40/42T: 11-13-15-18-21-24-28-32-36-40/42
11T - Hi tensile steel
13-28 - Chromoly
32-40/42 - Aluminum
terra
by terra
Getter wrote:Quick follow up. Went to Interbike and saw a company called Response. Ordered a three of their cassettes. Installed one on my 29er. Replaced the OneUp 42T and Wolf Tooth 16T add ons.
13-28 - Chromoly
32-40/42 - Aluminum
Interested, please update on durability/shifting etc after some use. Thanks.
jooo
by jooo
No experience with either, but NAVAL and DOVAL both have options floating around on eBay.
Getter
by Getter
I've only taken it on a few rides...but for now it seems to work good.
The best part is the 18 and 21T. You don't have the 15 to 19 jump like you do with the add on 42T's. I can feel the change in cadence when making the gear shifts. With the Response gearing...the cadence feels more consistent when shifting through those gears.
andreszucs
by andreszucs
Interesting: http://pages.ebay.com/link/?nav=item.vi ... 1447398596
wingman
by wingman
Does anybody have experience or opinion about Garbaruk components? Their 10 speed expander looks very nice.
TomHelly
by TomHelly
I'm using the OneUp 40t and 16t (removed 15/17) on a Sram 1070 cassette.
Shifting into and out of the 40t is fine with my X9 Type 2 derailleur. B-tension screw has plenty of room to go further in.
Shifting from the existing 13t --> OneUp 16t is rubbish... It doesn't shift with just a click of the lever like usual, you must oversight slightly after the 'click' in the shifter to get it onto the 16t. With a 34t on the front I find I am using that shift when on flatter ground or descending and it's a bit of a pain in the ass. Perhaps the Wolf Tooth 16t is better designed/clocked for shifting. Tempted to drop the 40 and go back to a 32t on the front so it shifts as good as standard.
Anybody else had issues with their 16t?
Getter
by Getter
Contact OneUp about the issues with the 16T. I read that they may have a version 2 of their 16T.
I've used both the OneUp and Wolf Tooth 16T's. I've found that they both feel the same...with the Wolf Tooth being marginally better. The Wolf Tooth looks like a reverse engineered OneUp with slightly more machining.
prodigy
by prodigy
You can also buy a Shimano M771 16t sprocket separately online. They're just 5-6€ and shifting is perfect.
Getter
by Getter
Its not a direct fit? You have to do some grinding of the cog to properly "clock" it.
