It is currently Fri Jun 23, 2017 5:02 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
 Post subject: Sub 10kg Anthem X
PostPosted: Thu Nov 07, 2013 9:03 pm
Hi all
I'm looking to build a sub 10kg (22lb) Anthem X 26er. Below are the components I'm looking to put onto the frame. Currently standing at 9.8kg with XT SPD pedals based on claimed weight.
Did not go with XX1 as the difference in claim weight of 70g did not justify the $220 difference in price to me.
Any comments appreciated. Especially on lighter components I can get with similar cost/quality.
Frame Anthem 2011 Small w/ Fox RP2 2440 (actual weight (aw)
Fork 2014 SID RCT3 w/ maxel 1472
Headset Integrated Headset 108 (aw)
Spacer Carbon 4pc 14 (aw)
Stem Kalloy Uno UL 60mm 7deg 86
Crank/30T/GXP w/BB X01 700
Rear Shifter X01 91
Rear Dee X01 252
Cassette X01 275
Chain X01 252
Brake F XTR M985 450 (aw)
Brake R XTR M985
Rotor F Ai2 66 (aw)
Rotor R Ai2 66
Handlebar Cobalt 11 680mm 141 (aw)
Seatpost Thomson Masterpiece 192
Saddle Evoke RXL 155 (aw)
Tire RoRo2.25 / RaRa 2.1 1005
Wheelset Crest/240s/Cx 1400
Grip KCNC Eva 15
Pedals XT SPD 343
Inner Tube Maxxis Ultralight 250
Chainstay Protector Lizard Skin 28
Cable Housing Jagwire 50
Rear Skewer KCNC Steel 30
9881g
 Post subject: Re: Sub 10kg Anthem X
PostPosted: Fri Nov 08, 2013 6:43 pm
What size wheels?
PostPosted: Fri Nov 08, 2013 9:33 pm
At that wheelset weight it will have to be 26".
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Sat Nov 09, 2013 4:37 am
Yes 26" pardon me for leaving that info out.
PostPosted: Sat Nov 09, 2013 7:34 pm
I don't know how durable the X01 cassette will be but other than that I think you have a good, solid build there... you could go lighter with more exotic parts, like say a german:a kilo fork, but you'd part with more cash and possibly sacrifice durability.
Looking over the list though you are missing skewers and a seat clamp.
PostPosted: Sun Nov 10, 2013 7:41 am
I am sporting relatively similar Anthem X, and here is my take on making it lighter:
Obviously pedals: If you want to stick with SPDs - get the Xpedo XMF08T. I have been running them all year and they have been just superb. They weight 216g!
Crankset: Ditch the spider and SRAM chainring. Get absolute black spiderless chainring. About 100g to be saved there.
Brakes: I would get the lighter Shimano M987 or Formula R1s.
Grips: I use bartape. Current favourite is Cinelli Gel Cork. Weights about 35g.
Housing: Get some FASI aluminium housing or XTR Yumea. Will save about 25g.
Chainstay protector: My Anthem frame came with factory installed copter tape. No need for any chainstay protector.
Tubes: Go tubeless. You can save a bit there - 40g or so, but there are bigger benefits to be had, like lower tyre pressure.
Hope this helps.
Stefan
PostPosted: Sun Nov 10, 2013 9:54 am
If you are not to fat get lighter handlebars, seatpost and grips - this alone can save you around 200 grams with the same performance.
I would get:
New Ultimate EVO wide 700mm flatbar: 118 grams
New Ultimate EVO seatpost: 120 grams
Neopren grips: 15 grams.
Other than that I would make think of getting another frame - newer designs could make you save about 500 grams.
My blog
PostPosted: Sun Nov 10, 2013 7:14 pm
My experience with Conti Supersonic tubes is that they suck. I've had no problems with Maxxis.
PostPosted: Mon Nov 11, 2013 12:39 pm
Not sure that brake weight includes adaptors so you'll be looking at circa 35g for the rear there unless it's a PM frame?
PostPosted: Wed Nov 13, 2013 2:09 pm
More actual weights and the real bike weight on a scale built up will most likely tell you you are further from your goal than you think. Not saying it to be a pain but to give you a better idea of your starting points when making comparisons to future potential upgrades throwing weight in to the equation
PostPosted: Sun Nov 17, 2013 9:19 am
Hi all! Much thanks for your advices! Made changes to my final shopping lists and the items are on their way. Will post real weight pics once they arrive for future references.
Hi Miceden, Stefan, Mads Kock
Prefer to go with the fit and forget with minimal maintenance possible for now. I am about 85kg kitted. The exotic brands are really enticing, 90g for a 680mm handlebar and 70g lighter for M987s compared to M985s...
BTW Seat clamp part of the frame weight. Fork with maxle included. I forgot rear skewers! Going with some KCNC steel 30g for rear.
Agree based on what I read so far. Going with the Maxxis Ultralight.
Its a PM for rear. Will direct mount the brake calliper.
Totally understand and agree. Much of the weight are actually extracted from bikescale.com and R2-bikes with exception of X01 grouppe which I was not successful in finding real weight pics. Fingers cross for now!
PostPosted: Thu Jan 09, 2014 2:18 am
Finally done! http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=122213
PostPosted: Sun Jan 12, 2014 6:34 am
My 2010 Anthem X2 was 21.79lbs/9883g as shown in size small:
[URL=http://s276.photobucket.com/user/Dilberto88/media/Light%20Bikes/DSCN0881.jpg.html]Image[/URL
PostPosted: Mon Dec 15, 2014 8:58 pm
Nice! Realise it's been awhile since I'm here.
PostPosted: Mon Dec 15, 2014 9:00 pm
protyne wrote:
Some changes (read weight addition) after the trail got a little too wet and I had to change to some heavier trail tyres. Hovering at 10.5kg now
Users browsing this forum: No registered users and 8 guests
