It is currently Mon Apr 24, 2017 4:36 pm
Post new topic  Reply to topic  [ 123 posts ]  Go to page Previous 1 2 3 4 5 69 Next
PostPosted: Tue Jun 24, 2014 8:51 am
Spot on. :thumbup:
PostPosted: Tue Jun 24, 2014 3:01 pm
Location: somewere floating between here and the other side
Tomas91 wrote:
Did you weigh it out with downtube & chainstay protector, BB bearings, headset bearings, bottle boss bolts etc. removed? That stuff can add some (sometimes suprisingly much) weight...
BTW, this is probably the main reason, why they don´t list their bikes´ or frames´weight. Not only it varies between sizes, it can also vary to some extent between two identical models.
I´m deciding between 9.8 and 9.8 SL, the SL looks better IMHO, has better, or rather more durable fork, lighter wheelset (Which I would probably replace anyway, so that´s not a big issue) and about 300 g lighter frame, but I´m not really sure, if that´s worth that 1.800 € of price difference. Probably I´m not that much of a weight weenie :-), but anyway, what´s your opinion?
I think i only had the bb bearings in not the rubber protector, but to be honest i first fly got rep,ace after the bb shell wasnt abke to hold bearings anymore and my replacement sl frame started crancking around seatpost after less than 500 km, the 27.2 syntace post is correct size wise but the frame isnt, hence the cracks, i have lost most of my sympathy for trek, i mean if they stuck with a normal bb shell ( treated ) and check there molds for sizing they woulndt have to advertise that they offer ' worlds best warranty policy'
Other than, it does ride really nice, i havent ridden other cf mtb but its stiff and comfy im still running the original 3 year old fox forks and an xtr groupset with thunder burt it sad just under 9.5 kilo very nice (;
PostPosted: Fri Jun 27, 2014 5:01 pm
Tomas91 wrote:
Internal cable routing isn´t really something I would miss anyway... I´m just tempted by that FOX fork and those 300 g of weight saving... But that price difference is just enormous. I could buy a set of top-notch carbon fiber wheels and sitll have a couple hundred € left, so I´ll probably act raitionally and stick with the non-SL version unless I got some super deal on that SL one.
That was my exact dilemma, I'm happy with the standard 9.8, although I must say the frame weight is a little disappointing. Stilll, 8.7kg for the bike isn't bad!
Re the 1100g SL frame - if Trek are like Scott (and I suspect they are) the lightest frames become 9.9s, the 9.8s are probably slightly heavier anyway, and may well have things like heavier paint. It'll also be a small size, and minus all the removable bits.
PostPosted: Fri Jun 27, 2014 7:33 pm
That is not a dilemma. Enjoy! For rough terrain these 200 gram is good for you. :)
PostPosted: Fri Jul 11, 2014 7:43 am
Went tubeless the other day. 9650 gr. Very nice experience for me to ride without tubes. Comfort.
PostPosted: Tue Aug 12, 2014 2:25 pm
New wheels and new rotors:
PostPosted: Wed Aug 13, 2014 9:36 pm
Is that the green ESI grips you've got? Was going to get a pair, wasn't sure they'd match well!
PostPosted: Thu Aug 14, 2014 8:05 am
The match is about 91%. :oops: 8)
PostPosted: Wed Aug 20, 2014 2:05 pm
Reckon they'd look a bit odd with Grip Shift too, one of them only being half the length. Black would probably make more sense...
PostPosted: Wed Aug 20, 2014 2:18 pm
9320 grams btw...
PostPosted: Thu Sep 04, 2014 2:46 pm
9319 gr. :waving: :lol:
PostPosted: Fri Sep 05, 2014 5:23 am
Nice ride PSM!
PostPosted: Fri Sep 05, 2014 10:08 am
Thank you!
Thinking of slowly uppgade to full XTR. Rotors allready changed. :oops:
PostPosted: Fri Sep 05, 2014 1:39 pm
My 21” Superfly Pro SL is on 8.75kg, no pedals.
It's 100% stock apart form a Bontrager XR-1 Front tyre, Tubless and XX1 Groupset.
FYI the 21” (XL) frame was 988g thats just the carbon and the Rear mech hanger, no bottle cage bolts, seat clamp, down tube protecter etc.
:beerchug:
Ben Read
Junior XC Racer
Trek Madone
Trek Superfly SL
PostPosted: Fri Sep 05, 2014 6:11 pm
:beerchug:
100% stock apart from... :doh: :no1:
There are no new unread posts for this topic. Before and After. Trek Superfly SL 9.9
in MTB
kingkongsfinger
Sat Aug 13, 2016 7:33 am
kingkongsfinger View the latest post
There are no new unread posts for this topic. Trek Madone 7 series 2014 and Campagnolo brakes
PinaRene
Thu Dec 08, 2016 9:06 pm
PinaRene View the latest post
There are no new unread posts for this topic. Campagnolo SR/Record/Chorus 2014 shifters & pre-2014 crankset: experiences?
neeb
18
1858
Mon Jul 11, 2016 1:03 am
neeb View the latest post
There are no new unread posts for this topic. 2014 EVO and 2014 Madone 5.9 frame and brake weight
BLD25
Thu Jan 19, 2017 1:08 am
BLD25 View the latest post
There are no new unread posts for this topic. 1999 Trek 5500 geometry is similar to what current Trek?
bikebike
Sat Aug 13, 2016 4:25 pm
AJS914 View the latest post
Users browsing this forum: kame and 8 guests
