It is currently Sat Apr 29, 2017 2:59 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Sun Nov 03, 2013 7:47 pm
I have a 2x10 sram xx front derailleur,but i would like to go to 2x9 gearing,so my question is,is it work?? Is this a big problem to have 10speed front derailleur with 9speed chain?? I have to say,that i can use it with an old sram gripshift so i can move the derailleur a bit on the lower or on the highest gears.
Thanks
PostPosted: Sun Nov 03, 2013 8:02 pm
With careful seting up (as always) it'll work fine
PostPosted: Sun Nov 03, 2013 8:40 pm
It will work, as I have been running similar setup (10 speed XTR front) with 9 speed chain some time ago. Now I run 10 speed chain on 9 speed cassette and all is well. The 10 speed chain (KMC X10-SL), because it is lighter ;-)
PostPosted: Sun Nov 03, 2013 10:10 pm
Sorry guys,i make a mistake,I have 8 speed cassette(just too many years of riding with 9sp). So,how about that?? Will or wont work?
PostPosted: Mon Nov 04, 2013 8:48 am
You are getting closer to not working. 8 speed chains are wider than 9 (and 10) so you may be getting into modifying the front mech cage to fit over the chain and make the shift without rubbing.
Also, if you are using an 8 speed chainset modified to a double, you may find the throw of the 10 speed front mech might not be quite enough (depending on if you are using an 8 speed compatible front shifter. Some combinations work some won't. If its a 10 speed (or 9) chainset, it might work better. You could also try a 9 speed chain to gain some space.
All said and done, if you are willing to spend some time tinkering you should be able to get it to function acceptably.
(i've got an "impossible" set up to work, a mish-mash of road, mtb, triple, double, 8 and 9 speed)
PostPosted: Mon Nov 04, 2013 9:20 am
So,using 9speed chain on 8speed cassette is better idea than 8/8 set?? Is 9 speed chain working good on 8speed cassette??
PostPosted: Mon Nov 04, 2013 10:01 am
In my experience you can safely (i.e. it still works ok) use a slightly narrower chain, so a 9 speed chain on 8 speed cassette will work, same using a 10 speed chain on a 9 speed cassette and so on.
The issue is at the front. What chainset/rings/shifter will you use?
PostPosted: Mon Nov 04, 2013 2:23 pm
If I'll use 9speed chain I'm gonna use 9speed chainrings,probably shimano,or truvativ 42/26T.
PostPosted: Mon Nov 04, 2013 2:35 pm
You'll probably manage fine then, just some tweaking of the top and bottom stops.
PostPosted: Mon Nov 04, 2013 2:57 pm
Thanks!:)
PostPosted: Mon Nov 04, 2013 3:04 pm
Definitely you can run a 9-spd chain on an 8-spd cassette. I'm doing it and it shifts better for it.
The 9-spd chain will be slightly wider outside than a 10-spd - approx 0.6mm, so as the others say most 10-spd FD's are probably going to be fine. Perhaps a little more finicky to set up, but will work.
There's sometimes a buggy.
One.
PostPosted: Mon Nov 04, 2013 5:13 pm
I thinking about X.0 on front
PostPosted: Wed Nov 06, 2013 3:45 pm
Shimano low mount are one of the lightest you'll find, a Deore triple is just 156g and a double specific 124g, not sure about the X0 but that is lighter than an X9 (175g for a triple) by a margin and much cheaper.
PostPosted: Thu Nov 07, 2013 10:43 am
Maybe you're right,but in my frame i have direct mount only:) so x0 is one of the lightest (xx is only lighter). I think my bike shoul be ready in next week,so i will give you an answer is everything is ok with gearing.
There are no new unread posts for this topic. Shimano double MTB Front Derailleur - real capacity (16T front tooth difference?)
in MTB
ooo
Mon Sep 26, 2016 10:22 am
TheRookie View the latest post
There are no new unread posts for this topic. Front derailleur
banik69
9
1029
Mon May 30, 2016 12:53 am
2old4this View the latest post
There are no new unread posts for this topic. S2-system on Campagnolo front derailleur
Daniel1975
Thu Jan 05, 2017 10:16 pm
Calnago View the latest post
There are no new unread posts for this topic. Campagnolo Front Derailleur Question
matty
16
606
Sun Mar 19, 2017 11:10 am
matty View the latest post
There are no new unread posts for this topic. Tiso front derailleur - FOUND
in Wanted
4ibanez
Sun Feb 05, 2017 11:41 pm
4ibanez View the latest post
Users browsing this forum: No registered users and 3 guests
