It is currently Sun Dec 17, 2017 6:50 pm
PostPosted: Tue Sep 24, 2013 9:56 am
Hey guys.
Light bicycles only list the ERD of their wide carbon 29er rims. And extralite has the predetermined spoke lengths but you need to know the spoke end diameter and after many e-mails light-bicycles is struggling to understand what measurement I want. So in the hopes of building up my bike 2 weeks earlier and not having to wait for the rims to come in, measure them then order the rest of the parts I am hoping someone has done this combo before and remembers the spoke length or has some light-bicycle wide 29er carbon rims lying around and can perform the measurement for me.
Thanks Nic.
PostPosted: Tue Sep 24, 2013 3:35 pm
From sheldon brown:
E.R.D.
Effective Rim Diameter. This is the rim diameter measured at the nipple seats in the spoke holes, plus the thickness of the two nipple heads.
Not quite sure what you (or Extralite) mean by "spoke end diameter", but it sounds like the same thing as the ERD as defined above (since the spoke end is ideally flush with the top of the nipple).
Rise Bikes
Wilier Cento1SR Disc
PostPosted: Tue Sep 24, 2013 4:08 pm
That's what I would have thought as well. But the guys at Extralite are saying ERD it's not an accurate way to measure. And they don't list the hub specs for a traditional spoke calculator. They have a chart with all the spoke lengths needed based on the spoke end diameter.
This is how they determine it.
http://www.extralite.com/Products/measu ... %20SED.htm
PostPosted: Tue Sep 24, 2013 7:23 pm
This is how they determine it. http://www.extralite.com/Products/measu ... %20SED.htm" onclick="window.open(this.href);return false;
Seems to me Extralite is calling into question the accuracy of the E.R.D. measurement because what I see described in the link above is synonymous with Sheldon Brown's definition of E.R.D. I am guessing that because they spec high tension for wheel builds with the hubs, Extralite wants hyper accurate ERD but since typically spokes are supplied in 1mm length increments, teh difference is not going to matter unless you have a Hozan spoke cutting tool or similar. I would suggest you use the LB supplied ERD and get the hub tech specs and use the DT Swiss spoke calculator which should give you accurate spoke lengths.
PostPosted: Tue Sep 24, 2013 8:29 pm
Agree with MS6073 that the number they are seeking is just a measured ERD. I guess they don't trust rim makers to publish an accurate number. I think you are making a mountain out of a mole hill here though. Personally I'd just use the LB ERD number and forget about it. If its a hub for j-bend spokes I'd google for the measurements of the hub and use a spoke length calculator myself; if not I'd go with the Extralite table. DT sell Aerolites in the US in even lengths so that's a testimony that they don't think getting spoke length more accurate than +/-1mm is necessary.
Rise Bikes
PostPosted: Fri May 23, 2014 2:19 pm
ive currently got the same dilemma. how did you go with this? was the ERD accurate?
PostPosted: Sat May 24, 2014 2:28 pm
If it helps in anyway I have just built up a pair of the wide 29 rims which had a measured ERD of 604mm v manufacturers 603mm
the hookless 29ers i also build had ERD of 594mm v manufacturers measurement of 592mm
PostPosted: Sun May 25, 2014 11:25 am
i also measured 2mm on top of what LB claimed, but someone was holding the spokes with nipples screwed in (same effect as the rubber band trick which i just couldnt do), and the measuring tape was going over their fingers so i attributed that to adding the 2mm
i was thinking of going with their measurement. hmmm.
if it is 1 or 2mm longer than it would ideally be, i dont mind if the spoke protrudes through the end of the nipple as ill be running tubeless anyway but i worry about there being less holding onto the threading so more chance of them coming loose.
my first wheel build you see, paranoid about everything and i know nothing. gotta start somewhere!
i also dont like the extralite 'tables' they use to calculate spoke length. it's not accurate, and combined with the lack of confidence i have in LB measurements (and my own measuring) i'm worried it will be out by 2 or more mm.
the wheelpro.co.uk length calculator is what bikehubstore recommend and it looks simple enough. im going to email asking their opinion and maybe post that here as well.
There are no new unread posts for this topic. J-bend spoke would not fit through Extralite CyberFront SL hub
in Everything wheels
professorandre22
Thu Aug 03, 2017 5:30 am
professorandre22 View the latest post
There are no new unread posts for this topic. Spoke length for Enve 3.4 wheel with Chris King R45 hubs?
kode54
Mon Jan 02, 2017 3:28 pm
kode54 View the latest post
There are no new unread posts for this topic. Light and wide wheelset
Vallinotti
Sun Sep 17, 2017 9:39 am
Beaver View the latest post
There are no new unread posts for this topic. Which light-bicycle.com tubular rim for CX disc race wheelset?
savechief
Fri Jul 14, 2017 5:18 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Light, wide, tubeless disc rim
morganb
Mon Sep 11, 2017 9:38 am
svendsvin View the latest post
Users browsing this forum: Yahoo [Bot] and 4 guests
