It is currently Wed Jan 17, 2018 6:44 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Fri Sep 27, 2013 2:53 pm
So that puts you within 8mm, which you can probably take up on the rails, now you just need to keep the bars at the same height!
PostPosted: Fri Sep 27, 2013 3:44 pm
{USERNAME} wrote:
HA is pretty much the same, WB the same, logic says to move the saddle back to the same effective place lengthening the cockpit and he'll be in the same place on the same WB....or is that too obvious?
While a greater setback post on the small frame can give the same cockpit length you are changing the saddle/ pedal relationship which IMO should be fixed in the correct biomechanical position and reach only adjusted with different stems. However people move their saddles all over the place and don't die so whatever works for you I guess
Also with a different ETT you change the weight distribution over the bike so the handling riding out of the saddle in particular may feel a bit off.
I don't know if any of these things might be noticeable but are the issues to consider IMO
PostPosted: Sat Sep 28, 2013 5:56 am
As the HA is near enough identical and the WB the same, the weight distribution will be the same, I agree about the BB position though, will be 20mm further forward relative to saddle and grips which may or may not be an issue (or even be an improvement...)
PostPosted: Sun Sep 29, 2013 1:13 pm
if going the medium route, would the changes in geometry compared to my current bike make a big difference in handling? Im trying to forget about the weight ;P
There are no new unread posts for this topic. bike weight and performance?
Alanor
16
1967
Wed May 10, 2017 10:18 pm
Nefarious86 View the latest post
There are no new unread posts for this topic. bike geometry help from the math guys...
chiltonp
14
1327
Tue Mar 21, 2017 7:19 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Bike geometry - judging comfort without sitting on it
mike001100
19
1212
Sun Aug 27, 2017 7:01 pm
morganb View the latest post
There are no new unread posts for this topic. Attachment(s) Zullo - Oria KK steel bike
JLS
24
4226
Fri Dec 01, 2017 12:54 pm
JLS View the latest post
There are no new unread posts for this topic. Niner RLT Steel 2017 Gravel bike build
leicaman
9
2236
Wed Jan 10, 2018 1:48 am
leicaman View the latest post
Users browsing this forum: No registered users and 3 guests
cron
