It is currently Sun Dec 17, 2017 1:46 am
Post new topic  Reply to topic  [ 14 posts ]
 Post subject: T30 M6 Titanium bolts?
PostPosted: Tue Sep 10, 2013 5:27 pm
Anyone know of a source for Torx T30 M6 Titanium bolts? Looked at TorontoCycles and JerseyCycles but only found torx bolts for mounting brake rotors. Also searched Ebay and found a seller in China but shipping apparently is via the proverbial slow boat from China estimated at 3-4 weeks.
PostPosted: Tue Sep 10, 2013 7:40 pm
I used to get bolts from exeneli-store.com but they seem to be gone, anyone know what happened?
And since they are gone I started to look for a supplier myself and that was not easy, Allen head everywhere
Torx nowhere.
Well if the site has a submarine or a mayor industry on their homepage as customer it is not for "3 bolts for my bicycle" anyway.
I will follow this thread!
Max Gravity, unfairly treated by gravity!
PostPosted: Tue Sep 10, 2013 10:38 pm
What is the requirement/ application for these? Just curious more than anything. Pro-bolt would be a good place to try if you haven't already but the bolt sounds unusual
PostPosted: Wed Sep 11, 2013 1:24 pm
Trying to lighten up an already light set of mechanical disc brakes by finding a source to replace the steel Torx T30 caliper mounting bolts supplied with TRP Spyre SLC mechanical disc brakes as well as possibly replacements for the two torx bolts that clamp the caliper body together.
PostPosted: Wed Sep 11, 2013 9:03 pm
Do the caliper mounting bolts need to have the T30 head? Like-wise with the caliper bolts? It would appear a normal M6 Ti bolt would be fine in any head variety that takes your fancy
PostPosted: Wed Sep 11, 2013 9:25 pm
Extralite do all manor of Ti bolts. Shipping from Italy to the US won't be cheap though.
PostPosted: Fri Sep 13, 2013 1:22 pm
any bolt head would work perfectly.
Happy Trails !!!
PostPosted: Fri Sep 13, 2013 2:01 pm
My thoughts exactly Liggero
PostPosted: Fri Sep 13, 2013 3:34 pm
Compromised after I found out Avid markets just the Ti T25 M6 button head caliper mounting bolts used with the BB7 SL calipers.
Yes, but the intent is to be able to make required adjustments on two or three bikes using the same tool.
PostPosted: Sun Dec 08, 2013 5:05 am
Look for Proti ffr ti bolts, the best in the market - http://www.protiglobal.com/good.php?fid ... lumn1=BOLT
also more info on this thread: viewtopic.php?f=7&t=121425
You can talk to me if want them, cheers!
PostPosted: Sun Dec 08, 2013 5:45 am
I have seen this posted all over the forums in the last few days. Are you affiliated with them?
What makes them best? How "regular" Ti bolts are not enough in bicycle applications? I know these are Torx head and ALL but this somehow does not make it suitable or practical.
Ti bolts are an expensive way to shave a few grams. These are even more expensive and limited corlors too.
:noidea:
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
PostPosted: Sun Dec 08, 2013 6:24 am
Ti bolts are an expensive way to shave a few grams. These are even more expensive and limited corlo too.
:noidea:
I will suggest you to take a look at their official explanation on the process to understand their retail price.
http://www.protiglobal.com/main.php
It just happened, I found this company on-line and felt like sharing with everyone. As a follow up from that I also had some communication with them and I can give you more updates if you are interested in the product.
PostPosted: Sun Dec 08, 2013 6:34 am
Point taken, however, price(and sizes/colors) is still too high for a bicycle application. Great find otherwise, torxhead :)
Chris.
Orbea Oiz - xxxx
PostPosted: Sun Dec 08, 2013 12:05 pm
Having just picked up SRAM XX1 I can't stand SRAM's exclusive use of Torxhead bolts! Don't know why but it drives my crazy. Replaced them with allen head bolts while going alu/ ti. Maybe I'm just becoming an old man and don't like change :D
There are no new unread posts for this topic. Ti Stem bolts
misterq
21
1894
Thu Nov 02, 2017 8:48 pm
misterq View the latest post
There are no new unread posts for this topic. Ti bolts...what places to use them am I missing?
Lewn777
19
2258
Sun Apr 02, 2017 4:19 am
froze View the latest post
There are no new unread posts for this topic. FS: Enve 27,2 seatpost, 2 bolts, like new- NOW 130
cdtf
Tue Nov 14, 2017 2:25 pm
cdtf View the latest post
There are no new unread posts for this topic. Chainring bolts torque spec
oldnslow2
Sun Dec 10, 2017 11:46 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Tune Sixpack Crank Bolts
in MTB
Feex
Fri May 26, 2017 4:02 am
Feex View the latest post
Users browsing this forum: No registered users and 4 guests
