It is currently Wed Feb 22, 2017 9:14 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Sep 06, 2013 5:32 am
What are people using to drop some grams with their through axles?
I have a Rock Shox QR15 (15x100) up front that weighs 74 grams
I have a Shimano AX75 (12x142) down back that weighs 96 grams
So far I've seen offering from Tune, Parts of Passion and Massi but all don't have favorable reviews for reliability or user friendlyness.
There's also Carbon Ti and FRM making bolt up versions that require a 5mm allen key.
http://www.frmbike.biz/index.php/en/sho ... gory_id/20
At this point I'm leaning towards FRM but just wanting to check if there are any other options out there.
Grover's Grumblings
Grover's Garage
PostPosted: Fri Sep 06, 2013 5:33 pm
Syntace X12 - 40g
PostPosted: Sat Sep 07, 2013 5:25 am
My impression is that Syntace X12 and Shimano e-thru are two different designs of 12x142 axle. Syntace X12 has a conical surface on the non-drive side while Shimano e-thru uses a flat surface. That means the Syntace X12 does not work with my frame. Correct me if I'm wrong.
Grover's Grumblings
Grover's Garage
PostPosted: Sat Sep 07, 2013 10:33 am
I have been using the Tune DC15 front for a while - no problems so far. Read somewhere about someone having problems with it loosen during riding but I haven't had this problem.
My blog
PostPosted: Mon Sep 09, 2013 8:33 am
That's right ;) I was hoping for cheap weight savings there but it doesn't work.
PostPosted: Mon Sep 09, 2013 12:27 pm
I've ordered FRM...http://www.componentsbike.it/ had them in stock at a decent price and happy to ship to Australia.
Grover's Grumblings
Grover's Garage
PostPosted: Mon Sep 09, 2013 10:12 pm
I too use the Tune DC15 for 2 bikes.
The threaded end that goes into the fork is actually threaded into the axle as well. One of my loosened over time. I used Loctite 243 to fix that. There is a hex that is broached inside the threaded end section that goes into the fork. Just cleaned it with some Alcohol and then let it try, then applied some loctite and that was it.
There is also a Skyline version of the DC15 that is even lighter. I think it is 2X the price of the DC15.
http://www.hackracer.com/
PostPosted: Wed Sep 11, 2013 2:51 pm
Location: somewere floating between here and the other side
Do you guys know if the tune/frm or syntace is compatible with the trek superfly sl frame?
Thanks mick
PostPosted: Thu Sep 12, 2013 6:20 am
Looks like KCNC will have something out soon:
http://www.bikerumor.com/2013/09/10/eb13-nifty-alloy-accessories-from-kcnc-cassettes-pumps-computer-mounts-thru-axles/
PostPosted: Sun Nov 24, 2013 1:30 am
Any news about cheaper axxles for 15 and 12mm?
PostPosted: Wed Nov 27, 2013 8:59 am
Online
Carbon-ti got a 15x100 option that is a bit lighter than Tune. But needs an allen key to use
/jonas l
PostPosted: Wed Nov 27, 2013 4:53 pm
The Kcnc ones are now available.
Fronts are currently only in Fox standard. Actual weight is 54 grams.
Rear are currently only in DT standard. Actual weight is 42 grams.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Tue Dec 03, 2013 1:41 pm
http://www.extralite.com/Products/Black%20Lock.htm
PostPosted: Sat Jun 14, 2014 3:38 pm
Online
Thanks mick
Old thread but asks the same question. Anyone know how Trek's ABP system is working with other axles? 90g axle wasn't so funny for my bike.
/jonas l
There are no new unread posts for this topic. Thru Axles....
in MTB
Unbrokenchain
12
1318
Mon May 16, 2016 4:38 pm
LeDuke View the latest post
There are no new unread posts for this topic. Cruel components thru axles
in MTB
HaakonJohansen
Tue Oct 11, 2016 4:34 am
Yveltal View the latest post
There are no new unread posts for this topic. Thru-Axles and Quick Release
Valbrona
Sun Mar 06, 2016 12:36 am
Fixie82 View the latest post
There are no new unread posts for this topic. TT shifter options
Kermithimself
Mon Jul 04, 2016 8:33 am
Kermithimself View the latest post
There are no new unread posts for this topic. XC wheel options
in MTB
teakay
Fri Dec 02, 2016 6:23 am
michel2 View the latest post
Users browsing this forum: cerro and 6 guests
