It is currently Tue Jan 16, 2018 2:57 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Mon Sep 02, 2013 11:44 pm
Is all mounting hardware for disc brakes universal? I am now using Avid Elixir CR disc brakes.....I am getting a pair of Formula R1 brakes that have no hardware included, will the Avid hardware I am using now work with the formula R1 brakes?? thanks!
to go faster....just pedal harder!
PostPosted: Mon Sep 02, 2013 11:52 pm
So long as they're the same mount system as in IS or post mount then they'll bolt straight on*
*afaik
PostPosted: Mon Sep 02, 2013 11:54 pm
thanks.....that is what I thought
PostPosted: Mon Sep 02, 2013 11:59 pm
The one thing you might wish to check is rotor width, I've got R1s on A2Z Teppan Yaki SP4 rotors and they're fine but I know some others have had issues with pad rubbing on R1s, should still be fine though.
PostPosted: Wed Sep 04, 2013 9:16 am
Guys I'm riding a XTC Composite with 180mm rotors fitted with adaptor (SM-MA-F180P/P2). What would I need to get down to 160F/140R? Would removing of the adaptor only allows down to 160mm front rear?
Thanks!
There are no new unread posts for this topic. Attachment(s) Why is no one using disc brakes in the tour?
[ Go to page: 19 10 11 12 13 ]
gceniza
186
17972
Sat Jul 22, 2017 8:29 am
lobuxracer View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1096
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
There are no new unread posts for this topic. Road Disc Brakes- Rotor Choice
[ Go to page: 1 2 3 4 5 ]
mdeth1313
73
7033
Fri Jan 12, 2018 12:57 am
simoncx View the latest post
There are no new unread posts for this topic. Aero carbon rims disc brakes
in Everything wheels
L3X
Mon Mar 20, 2017 10:55 pm
Marin View the latest post
There are no new unread posts for this topic. Attachment(s) In a 2017 ww world - what is the weight penalty of running disc brakes?
alcatraz
Sat Mar 18, 2017 5:53 pm
nemeseri View the latest post
Users browsing this forum: No registered users and 6 guests
cron
