It is currently Wed Jan 24, 2018 9:19 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Aug 30, 2013 9:32 am
hi all,i am thinking about making a lightweight seat post for my whyte19,i like the set back style post thats on there,i have searched the site and found that a few have made there own straight posts,but has anyone made a set back post??carbon tube is easy enough to find,just a bit stuck on how to make the setback part,do any of you weightweenies have some ideas,thanks for reading..
PostPosted: Fri Aug 30, 2013 10:47 am
Exotic carbon do the Cobra which is a full CF post rather than most CF laybacks which use a metal top section (like mine does!)
PostPosted: Fri Aug 30, 2013 2:37 pm
there post looks awesome,but only 27grams lighter than what i have at the moment,ideally,i would like to half that weight,around 110 - 130grams .
PostPosted: Sat Aug 31, 2013 6:05 am
That's the weight penalty of the layback, it inevitably uses more material as it has a higher bending load and a larger head section, do you need the full length or can you cut it down?
I can't see you getting a layback at that weight for the above reasons, the best inline aren't much lighter and the rules of physics play a big part here.
PostPosted: Sat Aug 31, 2013 3:09 pm
I took a Thomson Masterpiece setback with a carbon cradle, ti bolts, alloy yokes to get a light post (135g-140g for 31.6/300 setback).
PostPosted: Sun Sep 01, 2013 10:20 am
I think you will struggle to make a 110-130g setback seatpost since even the companies with the most experience and resources currently struggle too. I too am looking for a light post with around 15mm layback that doesn't cost the earth and have ended up with a tuned Thomson Masterpiece.
Maybe someone can correct me but I can not find a nice light 10-15mm layback seatpost besides a tuned Thomson Masterpiece. The MCFK comes closest but is 20mm offset and 349 Euro...
Maybe someone can help add to the list of light set back posts available? (weight in 31.6x350mm- taken from R2 Bike/ Fairwheel weights)
UPDATED WITH OTHER WEIGHTWEENIES' INPUT
AX Lightness AX2200--- 25mm offset??? --- 114g --- 467 Euro
Schmolke TLO Setback --- 25mm offset --- 116g --- 495 Euro
MCFK --- 20mm offset --- 119g --- 349 Euro
AX Lightness Daedalus--- 25mm offset??? --- 140g --- 355 Euro
New Ultimate Aluminium Setback --- 20mm??? --- 147g --- 120 Euro
Engage Revit --- 25mm offset --- 155g --- 195 Euro
Thomson Masterpiece --- 15mm offset --- 158g (w/carboncradle + ti hardware)--- 250 Euro
Crank Brother Cobalt 11 --- 20mm offset --- 180g --- 219 Euro
Ritchey Superlogic --- 25mm offset --- 181g (w/alubolt) --- 200 Euro
USE Alien Carbon --- 10mm Offset --- 188g (claimed) --- 94 Euro
Bontrager XXX --- 20mm offset --- 190g --- 160 Euro
Thomson Masterpiece --- 15mm offset --- 193g --- 175 Euro
KCNC SC Pro Lite --- 18mm offset --- 203g --- 71 Euro
ENVE --- 25mm offset --- 195g --- 280 Euro
PostPosted: Mon Sep 02, 2013 12:50 pm
DanW wrote:
Maybe someone can help add to the list of light set back posts available? (weight in 31.6x350mm- taken from R2 Bike/ Fairwheel weights) updated with some real weights
Thomson Masterpiece --- 15mm offset --- 158g (w/carboncradle + ti hardware)--- 175 Euro
Crank Brother Cobalt 11 --- 20mm offset --- 180g (stock) --- 219 Euro
Supersix HiMod, Supersix EVO HiMod, Crux, CaadX, Lynskey R330 & Pro29, Yelli Screamy 29
PostPosted: Mon Sep 02, 2013 1:04 pm
Cheers Frohrider :D
I have updated the original list with your weights and modified the tuned Thomson price to reflect the cost of the tuning.
I have a tuned Thomson Masterpiece but have found the rear bolt is not long enough to work well with an Alu Yoke (POP) as the nose of the saddle can not be low enough (to have the saddle around level- with the Alu Yokes it is very nose up). The threads in the original Thomson upper clamp sit almost at rail level whereas with the POP yokes the threads are above the level of the saddle rails and the bolt can not reach. Are there other yokes which work better?
To the OP: As before making your own superlight setback post in the weight range you want will be very difficult. I would have thought the easiest approach would be to copy the New Ultimate or Schmolke posts in my list
PostPosted: Mon Sep 02, 2013 3:56 pm
For the tuned Thomson Masterpiece with POP yokes i use the Easton EC90 Ti bolt kits for the rear yoke (those are 40 or 45mm vs normal 30mm?) and that works well.
The EC90 ti bolts have the same cone shape of the head so they work perfectly.
PostPosted: Mon Sep 02, 2013 4:26 pm
Thanks Tom, I knew there must have been some sort of trick like that top get these super light tuned Masterpieces up and running :)
PostPosted: Fri Sep 06, 2013 9:38 am
DanW wrote:
Cheers Frohrider :D
DanW i've been looking at the schmolke set back post,i like alot.so will have a go at something similar,and hopefully wont cost 495euro's,will post pics as i progress,carbon tube is on its way to me as i type :D
PostPosted: Tue Oct 01, 2013 4:25 pm
http://www.flickr.com/photos/99995515@N08/10039239586/
got tube finally,about 380mm long at the mo .will cut down,once top is done.74g at the moment,time its cut down ,maybe 10g lighter??
PostPosted: Tue Oct 01, 2013 10:34 pm
Where did you source the carbon tube from? Also what diameter is it?
PostPosted: Wed Oct 02, 2013 11:04 am
tube is 30.9,made by a friend of a friend,he makes carbon parts for F1 cars and
bikes ,so hopefully it'll be up to the job,took me long enough to get this piece,so dout i'd be able to source from him again as they are snowed under with work.
TOP piece i will fabricate,could be interesting. :D
I'm still determined to get the weight i want,and if i fail,then at least i got my hands in there and tryed.
There are no new unread posts for this topic. Can I make this bike a lot ligher?
dim
Tue Dec 05, 2017 12:25 pm
alcatraz View the latest post
There are no new unread posts for this topic. Anyone tried to make their own carbon orthotics/shoes
zappafile123
Sat Oct 28, 2017 6:23 pm
TheKaiser View the latest post
There are no new unread posts for this topic. Swift Ultravox: make offer
go4custom
Fri Dec 08, 2017 6:12 pm
go4custom View the latest post
There are no new unread posts for this topic. Anyone ever make the Team Sky rice cakes?
in Training
53x12
Tue Jul 11, 2017 8:51 pm
flying View the latest post
There are no new unread posts for this topic. How to make my Ridley Noah SL lighter??
fonzo89
12
1800
Thu Jul 06, 2017 10:55 am
hannawald View the latest post
Users browsing this forum: No registered users and 1 guest
