[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5150: memcache_connect() [function.memcache-connect]: Can't connect to localhost:11211, Connection timed out (110)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5150: memcache_get() expects parameter 1 to be Memcache, boolean given
Replacing battery FSA K Force light triple SRM - Weight Weenies
It is currently Sun Jun 25, 2017 1:00 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Mon Aug 12, 2013 9:08 pm
I need to replace my battery. This unit is a little different than the ones I've searched out that members have replaced. Any one know how to get the cover off? Do I need to unscrew the lock ring on the crank spindle? Any help is much appreciated.
PostPosted: Tue Aug 13, 2013 4:10 am
Take a look at DIY SRM Battery Change. The plastic torque cover has a slight lip which is probably obscured by the inner and/or middle chain rings. Once removed, you should see the lip and using a good source of light and possibly a magnifying glass, you will see there very small indentations around the circumference of the plastic torque ring. The torque ring is press fit onto the inner lip of the powermeter and I have used a very sharp shop knife but you can also use a jewelers screwdriver to carefully - plastic is very thin and easily deforms - pry the cover off.
PostPosted: Tue Aug 13, 2013 5:41 pm
Thanks! I got the cover off and will replace the battery. BTW, I ended up using a surgical scapel #10 blade b/c the fit was so tight. It's a good design to keep water out. Thanks again for your invaluable help. :D
There are no new unread posts for this topic. Attachment(s) FSA K-Force Light crankset BB386EVO
snowdevlin
Mon May 08, 2017 9:41 pm
snowdevlin View the latest post
There are no new unread posts for this topic. FSA K-Force light crankset with Shimano BB?
ave
Tue Apr 04, 2017 11:14 pm
MisterMuncher View the latest post
There are no new unread posts for this topic. Attachment(s) SRM Magnet Placement for FSA K-Force Light 1x Crankset
in MTB
HugoDrax
Thu Nov 24, 2016 1:50 pm
wetpaint View the latest post
There are no new unread posts for this topic. Attachment(s) spider for k-force light crank arms other than power2max?
lovemyway
Fri Feb 10, 2017 7:56 pm
lovemyway View the latest post
There are no new unread posts for this topic. 1x11 system, FSA SL-K Light or SRAM Force 1 cranks
Maggo
10
1633
Thu Aug 25, 2016 8:55 pm
Maggo View the latest post
Users browsing this forum: Baidu [Spider] and 5 guests
