Orbea Occam 29er - With Picture
wpccrunner
by wpccrunner
My boss got an Orbea Occam 29er FS and I just finished the prelim build.
Frame: Orbea Occam 29 Carbon S
Fork: Fox Float 32 29er
Shock: Fox Float CTD Evolution Series
Group: SRAM XX1
Brakes: SRAM XX w/ HSX Rotors
Wheels: Stans ZTR Crest
Tires: Conti X-King 2.4
Grips: Token Lock On
Other parts are still being tested/adjusted and to be replaced with higher quality
Pardon the bad pic, but got bored at work and snapped a quickie
savechief
by savechief
OK, I'll go first...what does it weigh?
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
wpccrunner
by wpccrunner
current weight is a hair over 24lbs with heavy aluminum seat post, bar, stem and pedals. Ritchey Paradigm pedals will be added with lighter bar/stem, but a RockShox dropper seat post is getting thrown on as well...
Vegard
by Vegard
I like it, what kind of bottombracket and fork mm does it have?
TheRookie
by TheRookie
SRAM XX1 groupset - it's in the specs!
Looks nice, by the time you've lightened those bits and added a dropper I guess it will weigh about the same as it does now!
Vegard
by Vegard
TheRookie wrote:SRAM XX1 groupset - it's in the specs!
That doesn't really tell me what kind of bottombracket the frame uses.. :unbelievable: :smartass:
wpccrunner
by wpccrunner
100mm travel
Standard SRAM GXP English Threaded BB
Swapped parts for dropper post, Ritchey WCS Paradigm pedals, and cut steerer, but still no decision on bar/stem yet. Currently 25lbs with swapping of parts
