It is currently Sun Mar 26, 2017 4:43 am
 Post subject: Rear QR Skewer?
PostPosted: Mon Jul 22, 2013 2:24 am
Have a few QR (10x135mm) related questions. As someone who weighs around 200lbs, a few grams don't bother me -- nonetheless, as I am on WW, any reasonable/practical weight-shaving is a good thing. :mrgreen:
- Has anyone, especially you "heavier" WW (+82kg/180lbs), had issues with light-weight rear QR skewer? For reference, I'm thinking of KCNC, Mt Zoom, etc.
- Based on what I've read, internal-cam QR is better than external-cam QR when it comes to clamping power and ease of use. Anybody besides Shimano currently makes external-cam QR (at a decent weight)? I know Tune used to.
- Any thoughts on moving from rear QR to thru-bolt QR like the DT Swiss RWS? Weight penalty?
 Post subject: Re: Rear QR Skewer?
PostPosted: Mon Jul 22, 2013 2:15 pm
Don't know if I am a "heavier WW" but at just over 80kg I have been using the KCNC Ti skewers for 2 years in all weathers and on all terrain without any issues. I can't vouch for other light skewers but the KCNC enjoy a good, robust reputation and I would have to add to those positive experiences of others. Fairwheel bikes did a good QR comparison which may be worth a read (I can't find the link quickly). Here are some updated thoughts from the same guys http://fairwheelbikes.com/c/forums/topic/12-high-end-skewers-reviewed/
I would expect 50% of the WW's replies to this thread to be to recommend the KCNC (maybe some of these to recommend Mt Zoom too) based on experience and the other 50% to recommend Shimano XTR based on a distrust of any skewer which is lighter than Shimano :D
PostPosted: Mon Jul 22, 2013 4:21 pm
Thanks for the input, DanW. I'll have one of each coming (Mt Zoom & XTR). Perhaps, I'll use the Mt Zoom for the CX wheel and XTR for my mountail/trail wheel.
btw...enjoyed reading your 18.5kg project.
PostPosted: Thu Jul 25, 2013 7:17 am
PostPosted: Thu Jul 25, 2013 1:08 pm
Isn't the Syntace X-12 for 142mm wide? Mine is 135mm.
PostPosted: Thu Jul 25, 2013 1:13 pm
Completely different dropout/ QR standard!
My German isn't great but it suggests the Tune QR tested has the best stiffness to weight ratio and the absolute stiffness is not much less than XTR/ 10mm thru bolt (for the various QR options for a standard hub/ dropout). I would expect the KCNC to be a little bit stiffer than the Tune for a pretty similar weight, although that is just speculation :D What "stiffness" refers to here in this test I am not sure though. It doesn't seem like there is much to choose from stiffness-wise for the various QR options for a standard hub/ dropout. Choose on weight, bling and reliability of the closure in that case :D
PostPosted: Tue Aug 06, 2013 1:59 pm
My understanding is that stiffness is almost irrelevant in a QR skewer. The dropouts are held against the hub by the QR being tightened to the point of stretching the metal, so it acts like a spoke. It's contribution to the stiffness of the rear end is negligible compared to the stiffness of the rear triangle and of the hub itself.
If I am correct, the reason steel skewers are more reliable than titanium is that steel has better elasticity. But all that being said, I used Ti skewers in the 80s, 90s, and now. I just check the tension every few rides, something I'd do with steel any ways.
PostPosted: Wed Aug 07, 2013 10:31 pm
Thanks for chiming in -- good stuff.
PostPosted: Fri Aug 09, 2013 11:07 am
TI is more elastic than steel (more deformation for the same load), so getting a good tension is 'harder' to judge as you need ;ess freeplay to start, as you don't exceed the elastic limit, once done up it shouldn't change.
PostPosted: Fri Aug 30, 2013 7:35 pm
I've got one pair of Tune ones and five pairs of Mt Zoom ones. I prefer the Mt Zoom ones, they are much easier to use, for example a larger handle makes them easier to open and close and they hav a definate 'close point' you can push the Tune levers too far.
On the 'pick it and feel it' weight test the Mt Zooms feel (just!) ahead.
Blog http://andrewhowett.blogspot.com"
There are no new unread posts for this topic. Skewer opinions
burglarboycie
27
2100
Fri May 13, 2016 5:49 am
VTBike View the latest post
There are no new unread posts for this topic. eBay titanium skewer
goleafsgo5
22
1324
Thu Mar 23, 2017 1:20 pm
racingcondor View the latest post
There are no new unread posts for this topic. KCNC Ti skewer setup question
stockae92
Sun Sep 11, 2016 5:04 am
eric01 View the latest post
There are no new unread posts for this topic. QR skewer shopping - Zipp v Enve v Reynolds
Shrike
34
1799
Tue Feb 07, 2017 5:00 am
Johnny Rad View the latest post
There are no new unread posts for this topic. Shimano CX 75 rear hub dimensions?
in Everything wheels
Multebear
Thu Sep 29, 2016 8:13 am
Multebear View the latest post
Users browsing this forum: F45 and 3 guests
