It is currently Thu Jan 18, 2018 2:33 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Jul 05, 2013 9:15 pm
Little idea here...
Carbon topcap with American classic tubeless valve cut to thread onto CO2 adapter
Removing the Star Nut I have full clearance to fit the C02, fitting is perfect!
For everyday use off race, Topeak Micro Rocket Carbon Pump fits perfect on 1/18 steertube
Co2 setup is heavier :(
:lol: :beerchug:
 Post subject:
PostPosted: Fri Jul 05, 2013 9:44 pm
My question would be how do you keep the headset tight? Fantastic idea though.
PostPosted: Fri Jul 05, 2013 10:04 pm
That's really clever! I'm going to make my own rendition of that now.
@deanh the top cap is just to preload the bearings before you tighten the stem on the steerer tube. It doesn't really provide much support in the sense that it keeps the stem on the steerer tube
Bike: Felt FC
Strava
PostPosted: Fri Jul 05, 2013 10:34 pm
NOTE!!! I would use this for LEFTY Forks ONLY!!!!!
Forgot to mention that! Since the lefty have the upper clamp as par of the tightening process on top of the stem, so at this point the star nut is useless after full installation.
PostPosted: Sat Jul 06, 2013 12:17 am
8)
Probably wouldn't be too difficult to modify a compression bung in order to attach the co2 cartridge to the bottom. Might not be real practical when your friends are waiting on you to change a flat, but pretty sweet idea anyway.
PostPosted: Sat Jul 06, 2013 1:02 am
I was just now out for a ride test....nasty and rocky down hills,Co2 stayed tight inside, no play.... and I even helped a random guy in need of a pump...solved his problem in 1min and back to the ride!
There are no new unread posts for this topic. show me your steerer tube ( inside )
stormur
Wed Jan 18, 2017 6:36 pm
stormur View the latest post
There are no new unread posts for this topic. Need pump for tubeless tires
in MTB
eyedrop
13
998
Thu Oct 05, 2017 7:40 am
TheRookie View the latest post
There are no new unread posts for this topic. Steerer offcut weight
SABARRAS
Thu Feb 02, 2017 12:29 am
SABARRAS View the latest post
There are no new unread posts for this topic. 0 Degree 1.25" Steerer Stems?
HugoDrax
Sun May 07, 2017 9:09 pm
HugoDrax View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon aeroad steerer plug adjustment
dannyBBo
Mon Aug 07, 2017 2:21 pm
alcatraz View the latest post
Users browsing this forum: No registered users and 11 guests
cron
