It is currently Sat Jun 24, 2017 8:36 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
PostPosted: Thu Jul 04, 2013 5:49 pm
Plan to get back into racing some XC, so grabbed a Lurcher frame while they were on offer over at On-one
not the lightest brakes ever, especially with the braided lines, but its not an all out "build as light as possible" more a mix of performance and durabillity to an extent build, so i didnt mind that, also having used them before and liking them i thought why not :)
Frame: 19.5inch On-one Lurcher
Forks: Fox Float 29er 100mm Remote CTD FiT Kashima 15mmQR
Bars: Crank Bros Cobalt 11
Stem: Crank Bros Cobalt 11
Headset: Chris King InSet3
Grips: KCNC Foam
Bar Ends: None
Front Brake Lever assy: Hope X2 Evo
Front Caliper: Hope X2 Evo
Front disc: Hope Floating 160mm Gold
Rear Brake Lever assy: Hope X2 Evo
Rear Caliper: Hope X2 Evo
Rear Disc: Hope Floating 160mm Gold
Hoses: Hope Braided
Shifters: XTR M980
Cables: XTR
Front Mech: XTR M986 Direct Mount
Rear Mech: XTR M986 Shadow+
Chain Device: None
Seat: Fizik Antares Carbon Braided
Seat Post: Crank Bros Cobalt 11
Seat Post Clamp: Hope Bolt on
Cranks: XTR M985 Race
Chainring(s): XTR
Chain: XTR M980 HGX
Cassette: XTR M980 11-34 Titanium
Pedals: XTR M980 Race
Bottom Bracket: Token BB92 Tiramic Bearing
Front Wheel:
Rim: Light-Bicycle Wide Profile Carbon
Spokes:
Hub: Chris King ISO 15mm axle
Tube:
Tire:
Back Wheel:
Spokes:
Hub: Chris King ISO QR
Tube:
Tire:
Still waiting for the carbon rims to arrive and off to Wheelcraft for them to be built and fitted and it should be good to go :)
PostPosted: Thu Jul 04, 2013 6:36 pm
Looks like a solid race bike! Do you happen to have a weight for the stem and seat post? I've been looking at them for a while, they're claimed weight sure is nice!
Also, If you remove the cable guide on the bottom of the fox fork you can loose ~50g, and if you move the cable entry on the remote lockout so that it faces forward it makes for a bit cleaner routing (less cable housing too). Similar to this http://ftp.cyclingnews.com/photos/2008/tech/features/fox_racing_shox09/Fox_Racing_Shox_2009_RL_Remote_top_cap.jpg
PostPosted: Thu Jul 04, 2013 8:59 pm
thanks for the tips there :thumbup:
i will weight the stem and seat post for you no problems, just need to get hold of a scale :)
PostPosted: Fri Jul 05, 2013 10:55 am
Very familair looking pics from your thread on 'that other' forum!
Not at all jealous........
PostPosted: Fri Jul 05, 2013 12:53 pm
yea haha same pics!
not much progress...dont have a headset press so borrowing one today, hopefully get more done to it :)
no rush :)
PostPosted: Fri Jul 05, 2013 7:08 pm
now pressed...
had to improvise with a rotor as the bottom cup was too large for the press to hold onto
no problems
PostPosted: Fri Jul 05, 2013 9:37 pm
According to CB that stem is 125g for a 100mm, while the bars are 160g for risers
http://crankbrothers.com/stems_cobalt11.php
http://crankbrothers.com/bars_cobalt11.php
PostPosted: Fri Jul 05, 2013 9:46 pm
stated weights on boxes for what i have
80mm stem: 125g
600mm flat bars : 132g
350mm seatpost: 157g
dont have scales so i can't accurately weigh anything unfortunately
PostPosted: Sat Jul 06, 2013 7:32 am
finish it finish it!!! really intrigued by this one and I am a roadie...
PostPosted: Sat Jul 06, 2013 1:08 pm
Surely an On-One needs to be made out of finest Doncaster gas pipe?
PostPosted: Sat Jul 06, 2013 2:55 pm
just taking my time, fitting a bit here and there... :mrgreen:
PostPosted: Sat Jul 06, 2013 3:33 pm
contemplating putting a spacer under the stem as there isn't much room to play with, due to the stems design...
thoughts?
PostPosted: Sat Jul 06, 2013 9:25 pm
I'd always start with at least 20mm of spacer and play with stem height, get it right and then and only then do the last steerer vut!
PostPosted: Sat Jul 06, 2013 11:17 pm
Steerer cut and everything roughly bolted up and ran cable wise bar shifters
PostPosted: Mon Jul 08, 2013 8:11 am
Looking good....how are the wheels coming along?
There are no new unread posts for this topic. 29er fat bike`
in MTB
bm0p700f
Mon Aug 01, 2016 11:37 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Scott Scale 29er
PastaDiPipo
Fri Jun 09, 2017 1:14 pm
PastaDiPipo View the latest post
There are no new unread posts for this topic. Dt-240s hubs for a 29er
in MTB
wheeler
Mon Jun 19, 2017 11:32 pm
wheeler View the latest post
There are no new unread posts for this topic. Relatively budget 29er HT frame recommendations
in MTB
whyamihere
10
1597
Mon Jan 09, 2017 6:52 pm
Ghastly View the latest post
There are no new unread posts for this topic. 29er frame with rear rack mounts?
Cornholio
Wed Aug 31, 2016 11:20 am
Cornholio View the latest post
Users browsing this forum: batcave and 1 guest
