It is currently Fri Jan 19, 2018 1:15 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sat Jun 22, 2013 2:19 pm
Hi
Can anyone on here help me get hold of one of these. The reputable bike workshop who replaced my pf30 bb decided not to bother re-fitting it and left me with 9mm of play in my bb. They are on back order in the uk but if anyone out there can find one I'd be very grateful.
It's a sram/truvative BBS007 I believe that is needed.
Thanks
Nick
PostPosted: Mon Jun 24, 2013 1:27 am
You can probably make one out of a 1 1/8" x 10mm headset spacer - this is what I did for Hollowgram axle spacer on my Funk (see signature). It'll start out with a 28.6mm (or something like that) inner diameter, but you can work on that with some 200 grit sand-paper until its 30mm. Same to grind the thickness down from 10mm to 9.11mm... you just need some decent calipers to keep track of progress, and to make sure that you randomize your sanding to ensure it is even (keep spinning it around in your hand so you eliminate the tendency to over-sand in any one area, and put the sandpaper on a hard flat surface... I managed to get mine down to 9.0mm +/- 0.02mm!).
Rise Bikes
Wilier Cento1SR Disc
PostPosted: Mon Jun 24, 2013 4:36 am
I also made the spacers I need for my Zipp cranks on my Tarmac out of carbon headset spacers. I used the sanding drum on my dremel to make quick work of the task..
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Mon Jun 24, 2013 11:00 am
Congrats for the tdf project yellow tarmac. Which size is it?
PostPosted: Mon Jun 24, 2013 1:04 pm
Thanks, it is a 52
Flickr
Follow on Instagram
There are no new unread posts for this topic. 30mm Axle / BB Spacer with < 0.5mm height?
jbattermann
Tue Aug 08, 2017 6:36 am
sungod View the latest post
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. Colnago C60 fork: are spacer under/ above the stem necessary?
TonyM
Mon May 22, 2017 3:17 pm
Calnago View the latest post
There are no new unread posts for this topic. Mag 150 with Carbon Axle?
whydobearsxplod
Fri Sep 29, 2017 11:30 am
ms6073 View the latest post
There are no new unread posts for this topic. Thru axle adapter
markyboy
7
434
Wed Dec 13, 2017 12:42 pm
Users browsing this forum: Mtek, simoncx and 6 guests
