It is currently Fri Oct 20, 2017 3:28 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Tue Jun 11, 2013 3:05 pm
my bike shifts good on my cheap sram 10spd cassette but shifts badly when on the bigger cog of my XO cassette.
The XO cassette is brand new, the cheap one has a bit of mielage on it but not much, and the chain was replaced earlier this season, not long ago too. I changed the cable and housing last week but the problem persists on the XO cassette.
Any idea what it could be? I will look at the B-screw setting just because I ma not sure it's well set and will look at the pulley wear. Will any 11T pulley do the trick, like this one http://www.chainreactioncycles.com/Mode ... elID=49729
thanks
PostPosted: Tue Jun 11, 2013 9:43 pm
Is the largest ring the same size on both cassettes?
Did you re-index at all when you changed cassettes?
PostPosted: Tue Jun 11, 2013 9:48 pm
yeah ring is same size. I tried to index it to the new cassette when I changed cable and housing but it wasnt succesful, then all was good when going back to my older cassette. There is a clicking noise when going onto the 2nd or 3rd innermost cog on the new cassette.
PostPosted: Wed Jun 12, 2013 5:39 am
obviously ensure the b-tension is set at 12mm from the bottom of the big cog when the bike is in the easiest gear.
the x.o cassette tends to sit a little more inboard than their other cassettes (fractions of a millimetre). do you need to screw out the low limit screw a little? if this is the case then you probably do need a bit more cable tension compared to your old cassette as well.
if that doesn't work start from the beginning and check your derailleur hanger. i've found that x.o and x.x cassettes are more sensitive than cheaper cassettes.
Grover's Grumblings
Grover's Garage
PostPosted: Wed Jun 12, 2013 11:20 am
thanks thats helpful grover!
I have played with the L screw yesterday as the derailleur was sitting a bit too much toward the spokes. The cassette now shifts better, the only clicking noise I can hear now is when on the small ring and on the 36T cog at the back, think I can live with that clicking noise for a while...
PostPosted: Wed Jun 12, 2013 7:10 pm
Have you checked the front derailleur? If the cassette sits more inboard clicking noise might come from chain hitting your FD.
PostPosted: Thu Jun 13, 2013 1:08 am
definitly not the case
There are no new unread posts for this topic. Sram red 22 shifting issue
Olivv
10
799
Tue May 16, 2017 5:44 pm
Olivv View the latest post
There are no new unread posts for this topic. RD-R9150 shifting issue with 9070 components
ottavik
Sun Mar 12, 2017 8:04 pm
spartan View the latest post
There are no new unread posts for this topic. Attachment(s) Front shifting with close ratio cassette
vinuneuro
Fri Aug 25, 2017 2:57 am
2lo8 View the latest post
There are no new unread posts for this topic. SRAM shifting with Di2
sturvey
Sat Mar 11, 2017 6:28 am
Racingevo View the latest post
There are no new unread posts for this topic. Problem shifting Campy 11
shampoo
7
807
Sun Nov 20, 2016 8:19 pm
Attermann View the latest post
Users browsing this forum: No registered users and 9 guests
